Price: $9.99
(as of Sep 03, 2024 01:00:22 UTC – Details)
Attention Please-Since the inflammable compounds, such as the candle wax, paper scraps, etc., tend to conver on it to stop the electric arc. Please clean the ignition part with a piece of dry cloth or napkin regularly (wet cloth is not allowed).LED Battery Display-Four battery indicators can display real time battery volume, when charging, the indicators will flash in sequence, when 4 LED lights on the barrel turn on, it is full charged. One charge, the lighters may contiguously work for using hundreds of time.Safety Protection & Design-You need to slide out the safety lock first, then press the button to generate sparks. The spark will stop automatically after 7 seconds of ignition.Flexible Neck Design-IUIRE lighter has a long flexible neck, it can be easily rotated 360°for different lighting needs. Windproof & Widely Used-Long lighter adopts flameless arc technology, can be used for strong wind or other bad conditions which is perfect for lighting candles, fireworks, gas stove, camping BBQs.Portable Lighter-The size of the lighter is very small and slim. It is suitable for daily use.Package Included -Electric rechargeable lighter, Type-C charging cable, a gift box,.
Hanging Hook
The candle lighter is very suitable for indoor use. You can hang it up anywhere. The arc lighter is perfect for candles, grill, fires, fireplaces, BBQ and outdoor campsites, etc.
Safety System
·Short-circuit Protection
·Overload Protection
·Smart Chip
·6S Power Off
4.8 out of 5 stars
176
4.8 out of 5 stars
176
4.8 out of 5 stars
176
4.8 out of 5 stars
176
4.8 out of 5 stars
176
4.8 out of 5 stars
176
$5.49$5.49 $5.49$5.49 $5.49$5.49 $8.49$8.49 $6.98$6.98 $15.99$15.99
Connector Type
Type-C Type-C Type-C Type-C Type-C Type-C
Rechargeable Battery
Retractable Protect
806
806
806
806
806
$7.99$7.99
— $5.49$5.49 $8.49$8.49
Length
10inch 10inch 10inch 10inch 10inch
Battery
220mAh 220mAh 220mAh 220mAh 220mAh
Connector Type
Hanging Hook
4.5 out of 5 stars
303
4.5 out of 5 stars
303
4.5 out of 5 stars
289
4.5 out of 5 stars
289
4.5 out of 5 stars
289
$7.99$7.99 $7.99$7.99 $7.99$7.99 $5.49$5.49 $8.99$8.99
Length
7.48inch 7.48inch 7.48inch 7.48inch 7.48inch
Battery
Connector Type
Weight
1.13oz 1.13oz 1.13oz 1.13oz 1.13oz
Flashlight
LED Battery Display: Four battery indicators can display real time battery volume, when charging, the indicators will flash in sequence, when 4 LED lights on the barrel turn on, it is full charged. One charge, the lighters may contiguously work for using hundreds of time.
Safety Protection & Design: You need to slide out the safety lock first, then press the button to generate sparks. The spark will stop automatically after 7 seconds of ignition.
Windproof & Widely Used: Long lighter adopts flameless arc technology, can be used for strong wind or other bad conditions which is perfect for lighting candles, fireworks, gas stove, camping BBQs.
Flexible Neck Design: IUIRE lighter has a long flexible neck, it can be easily rotated 360°for different lighting needs.
Attention Please: Since the inflammable compounds, such as the candle wax, paper scraps, etc., tend to conver on it to stop the electric arc. Please clean the ignition part with a piece of dry cloth or napkin regularly (wet cloth is not allowed)
