Camecho Vehicle Backup Camera 9 Inch 4 Split Monitor+ 4 Cameras with Front & Rear View Camera 18 IR Night Vision Waterproof Auto Camera with 2×33 ft and 2×65 ft Cables for RV, Trailer, Bus,Trucks
Price: $169.99
(as of Aug 13, 2024 17:30:14 UTC – Details)
22
9 Inch Monitor: 4 Split Screen
Support 4-channel video input display at the same timeClear Image: 800(RGB)×480 pixels revolutionWide range of application power supply 12-35V
CAMECHO SPLIT SCREENCAMECHO SPLIT SCREEN
9 Inch 4 Split Monitor:
Voltage:DC12V-35VChipset:MST703+5885Screen size:9”Screen resolution:800*480Power output:1000MAWork temperature:-10-60°Language:English/French/Spanish/German/Italian/Portuguese/Dutch/Chinese/Turkish
6 Display Modes Select :
Screen can be set to display 1/2/3/4 channels at same timeCH1-CH4 display image from V1-V4 connector accordinglyAutomatically Switch: After proper witing, the monitor will automatically switch to single channel of rear view camera image when the reverse gear is pulled(Operated by remote) Image can be rotated horizontally and vertically for mirror or normal viewingMore setting on remote control “Menu”: select settings of Brightness, rotate image, contrast, language. Etc
MINOTORMINOTOR
22
4 Extension Cables with 4-pins Aviation Connector
Provide both video signal and power in one cable, no need to wire extra power cable for camera
Strong anti-interference capabilityStable signal transmittionScrewing connection, away from falling offWaterproof case, protect the connector from rustiness4 cables in total: 2 x 10 meter (33ft) + 2 x 20 meter (65ft)
NIGHT VISIONNIGHT VISION
WATERPROOFWATERPROOF
LENSLENS
Great night vision
18 IR lights automatically activate in low light Provides clear images even at night
Reliable structure
Metal frame, sturdy constructionIP68 waterproofView Angle: 120 °
Upgraded lens
Powerful material lens away from deformationNo color changeResolution: 800 TV lineNo distance guidelines on images
REMOTE CONTROLREMOTE CONTROL
9 SPLIT SCREEN9 SPLIT SCREEN
What will I receive if I buy this product?
Package included:
1 x 9 Inch Monitor1 x Dashboard Mounting Bracket1 x Power Cord4 x Cameras2 x 33ft Length Cables2 x 65ft Length Cables1 x Remote Control
9 Inch Split Car Rear view Monitor: 4-channel video input, screen can be split into two or three screen displays at same time, each screen can be individually. Image can be rotated horizontally and vertically for mirror or normal viewing, meet your demand
Professional Car Back up Camera: 9″ Color TFT LCD monitor + 2 rear view cameras & 2 front view cameras + 4 pin connectors cable. Hardwired connection provides you a more stable signal, gets more clear image
Front Rear View Camera: 2 front view camera without guidelines + 2 backup camera without guide lines, 140 degree wide angle catches more blind angle, IP 68 waterproof and 18 IR lights night vision provides you a clear image
Easy to Install: Only need monitor connected to power, then the power could transfer from 4-pins aviation connectors extension cable to camera, needn’t to connect more cable, solve wiring inconvenience
Power supply: DC12V-35V- video cable connection. The cable length about 20m(65.6ft) and 10m(32.8ft) , so it is perfect for most cars. A wide camera lens viewing angle makes sure that you can see enough to park and reverse safely.Eliminating dangerous blind spots. Protect your car around of Kids and little pets.
