Camecho DC 12V 24V Vehicle Backup Camera System 2 x Rear View Camera Support Night Vision Waterpoof & 7″ Monitor with Dual 34ft AV Cables Hardwire for Bus Truck Van Trailer RV Campers
Price: $75.99
(as of Sep 02, 2024 21:30:18 UTC – Details)
1111
Backup Camera System Specification
Monitor 7 inch color monitor Resolution 800*480 System PAL/NTSC auto Power DC9V-35V Power consumption about 6W Video 2 video inputs Rear view pictures: Can be overturned by the butons of Up / Down / Left / Right Remote control All functions can be operated by remote control, or buttons on the device Weight about 0.7KG Backup camera 2 Waterproof night vision Backup cameras white balance Auto white balance Specification Lens: F = 2.15mm F4.05; TV Line: 480; Image Sensor: 1/3 “SONY CCD IP IP68 waterproof, shockproof, high temperature and high humidity resistance View angle 120 degrees Operating voltage 9V-35V Video Output Composite video cable
1111
22
22
Super Color Night Vision
With 18 IR LEDsThe rear view range is up to 15m road conditions behind the car, reduces the invisible blind spot to a greater extent.IR turn on automatically in low light
IP68 Waterproof
Metal frame, strong constructionIP68 waterproofCan use at rainy or snowy
With guide lines
This backup camera system is Built in Parking Assistance Guide Line , Gives a Reference For On How Much Room You Have Left Behind You.
11
22
22
Multiple installation methods
We provide mounting brackets and sticker boards, you can stand the display or hang it upside downA variety of ways to choose from
Wide View Angel
With 120° wide view angleKilling blind spot and readicating potential risks
Remote Control
Rear view pictures can be overturned by the butons of Up / Down / Left / RightAll functions can be operated by remote control, or buttons on the device
FAQ
Regarding the inability to switch V1/V2 on the display:
The monitor power cable has 3 colors cable: blue, red, black.The blue wire is reverse trigger wire.If the blue wire is connected to the backup light positive, the switch button on the screen is useless, you need to use the remote control to switch V1/V2.If you connect the blue wire, when you pull the reverse gear, the display will automatically display the V2 imageIf you want to switch V1 / V2 directly on the monitor, please do not connect the blue wire.
111111
Advantage and Wide Range of Applications:
DC 12V-35V power input, more safe, fit most of large vehicles, such as RV, truck, trailer, bus, motor home, caravan and campers
1111
Install this item is a very interesting process. Kindly try the following procedure steps.
Two cameras can connect to constant power or backup light source.
1. Monitor port:
The monitor has a red, black and blue (green) cable. The red wire connected to positive 12V, black wire to ground, the green(blue) wire is V2 reverse trigger. You could connect blue wire to backup light positive source. When car shifts into reverse, monitor will show V2 image automatically. If you want 2 cameras full time working, do not connect with blue wire. Use AV cable to wiring 2 cameras to the monitor directly.
2. Camera Port
Package include 2 power cord, connect camera to backup light power, red wire to positive, black wire to ground. Or use constant 12V/24V battery to power on two cameras. According to your needs, to adjust camera mount location.
When car driving on road, you could switch picture by V1 / V2 button or remote control. According to install wiring diagram , to test your product before hooked up onto vehicle:
Backup Monitor: 7 inch TFT LCD widescreen with high resolution, full color, PAL/NTSC auto, 2 video inputs. Switch picture by V1/V2 button or remote control. Come with remote control and stand.
2 Rear View Cameras: Depend on your needs, you can adjust install camera location. Switch picture by V1/V2 button or remote control. Rear view camera: IP68 waterproof, with reversing line,18 individual Infrared (IR) LED night vision support 30ft (max).
A/B button doesn”t work?: If the blue wire connected to the backup light positive, the switch button on the screen is useless, you need to use the remote control to switch V1/V2
Advantage and Wide Range of Applications: DC 12V-35V power input, more safe, fit most of large vehicles, such as RV, truck, trailer, bus, motor home, caravan and campers
Reliable & Friendly Customer Service: Our customer service are ready respond within 24 hour; 30-Day Money Back Guarantee; 12 Month Replacement Warranty, and Lifetime Support Guarantee.
