Camcorders 7″ Wireless Backup Camera System, 1080P 7″ Monitor Waterproof Side Rear View Cameras Recording Stable Signal Parking Lines CW703
Price: $159.90
(as of Sep 16, 2024 19:30:12 UTC – Details)
XROOSE CW703 WIRELESS 3 BACKUP CAMERAS 7 INCH RECORDER MONITOR FOR RV TRUCK TRAILER BUS VAN, etc
Wireless 7“ Backup Camera SystemWireless 7“ Backup Camera System
Tips for Xroose CW703:
1. The mount has double-side tape for the monitor, you dont need to drill hole on your dashboard.
2. For winshield mount, it included the suction cup mount.
3. Monitor can be powered by car charger or hardwired by power cable, that’s why we have 4pcs power cable in the package.
4. All the kits and the function of the system are full check by our staffs, so sincerely hope that you dont angry with this if something wrong. It may caused by the delivery, just get ahold with us is ok.
5. Sometimes facing the problem of signal reception, as for the extension you can hold it out the window, it will help you a lot and get ahold with us for the extension antenna.
6. If one day, the unit became blurry or other damaged, you can just get ahold with us is ok, we will help you, always have, always will.
Thanks!
Packinglist:
1. Three cameras, one for rear view, the other 2 cameras for side view when turning left or right
2. 1080P recorder monitor with touch button, 7 inch size, 32gb sd card
3. 1pc upgraded mount for rear view camera
4. 4pcs DC power cord, 4pcs antenna
5. Car charger with extra USB port
6. U-shaped dashboard mount and suction cup mount
7. Installation screw kits
Capacitive Touch Button ScreenCapacitive Touch Button Screen
Digital Wireless Signal TransmissionDigital Wireless Signal Transmission
100FT STABLE WIRELESS SIGNAL TRANSMISSION
FROM CUSTOMERS’s SHARING
Great picture! Great picture!
Happy CamperHappy Camper
Nice Picture Quality and Easy InstallationNice Picture Quality and Easy Installation
Excellent wireless backup camera system
Write on May 26, 2020
System bench test and set up prior to installation was simple, I had this wireless backup cameras system working within minutes. An SD 32GB memory card came preinstalled. The card can be formatted from within this 7 inch monitor and it can also be easily swapped if necessary. Video files are AVI format and can be easily downloaded to a PC or Mac using a card reader for full control of viewing or editing. Images can be mirrored or flipped 4 different ways. Up to 4 cameras can be paired to the monitor and scanned with adjustable delay or simultaneously in split screen mode. Image quality is excellent. The cigarette lighter plug for monitor power has a built-in USB charger port. There are two extension cables of different lengths for camera power. Monitor brightness is adequate, resolution is excellent. Wireless range is excellent. Signal strength is displayed on the screen. Overall, I am very satisfied with this purchase.
Great backup cameras for my camper!
Write on June 2, 2020
Great picture quality. While at 65 mph the signal isn’t perfectly smooth, it is quite good. I understand even the most expensive wireless backup cameras systems are not perfect at high speeds. I mounted the rear camera on the upper rear center of my RV trailer. Because of the height, the back up lines appear a little too wide. I did place shims under one side of the camera base also to make the lines center with my trailer. While the camera and monitor were a great value already, I was surprised to see there was also a coupon/instructions for a free dash cam in the box. Not many sellers send you free stuff. The dash cam so far is pretty good also, especially for free. I later decided I wanted a tiny camera on the license plate to help hook up the trailer. It is too cramped for a large camera.
Nice picture quality and easy installation
Write on July 15, 2020
Very impressed with this wireless back camera! It was easy to install on my trailer and very suitable for my 48ft trailer. I like how the wireless backup cameras system is wireless between itself and the monitor. I have a 48’ gooseneck trailer and a full size bed dually pickup and the signal had no problems reaching from the back of the trailer to the dashboard where I have the monitor. Most of the other cameras I’ve seen are very limited in distance but not this one.
The picture quality was amazing too – much better than I thought it would be. It does require a 12v power source near the camera so be aware of that. The cord is 8-10 feet long though.
The only downside is the camera is a little bulky – I would have liked to put it in the back window of my other RV but it wouldn’t fit behind the window shade.
The camera does have backup help lines but you can turn them off if you don’t want to use them.
Very happy with this purchase!
4.2 out of 5 stars
405
5.0 out of 5 stars
3
4.3 out of 5 stars
5
3.4 out of 5 stars
8
3.5 out of 5 stars
8
Monitor Size
7 inch 7 inch 9 inch 10.1 inch 10.1 inch
Camera
1 3 3 3 4
Wireless
1080P
Record Functiuon
Touch Button
Adapter Mount and Wires for Furrion Pre-Wired RVs, click to Xroose’s store or search us for help!
Supply the Furrion adapter, click to Xroose's storeSupply the Furrion adapter, click to Xroose's store
【4CH 1080P Capacitive Touch Button Monitor】More advanced 3D noise reduction technology makes the picture more restored, as well as the WDR processing technology won’t make the picture overexposure or too dark, making it more clearer and natural. Germany hi-tech on capacitive touch button sensor, less the possiblity of water-in, more durable and smoothly as well as extend the service life.Multiple camera compatible. Three cameras were included, and this system can take up to four cameras.
【Extra Long Range Stable Operation Signal】AHD tech with extra long distance picture transmission, high rate and anti-interference. In the actual usage, refer to CM1 system, it wont happened delay within 100m/328ft after our testing on the open area. No interference, upgraded long range wireless signal can stay smooth and clear even car speeds up to 75Mile.(mentioned on the product description about the difference of AHD/HDCVI/HDTVI technology)
【Two Bracket & Three Camera】One is dashboard bracket, the other is windshield mount which do not interfere with viewing while driving/ reversing. Switch ON/OFF for parking guidelines. Wireless 149 degree wide view backing up camera can be adjusted the installation angle to cover more dead spots.IP69 high rate waterproof let it work well no matter how long it rains. Anti foggy/snowy/water/high or low temperature. Xroose also supply more wireless camera separetely.
【Powerful Wireless Backup Camera System-CW703】Built-in 32GB SD card to storage video, the maximum storage of this rearview system up to 128GB. Keep recording at least 8 hours as well as seamless loop recording saving the cost of dash camera, help you record evidence once happened any accident. Wireless backing up camera can be adjusted the installation angle to cover more dead spots. IP69 high rate waterproof let it work well no matter how long it rains.
【2 Steps Installtion】Easy to install.Connect camera to reversing/running lights or other constant power, then connect the monitor to 12-24V cigarette lighter(2nd way: use the included kit to hardwired the monitor), no need to run wires to connect camera and monitor. The best choices of backup camera system for RV, Trailers, Trucks, Camper, Van, Motorhome, 5th wheel, Tractor, Pickup Truck, Semi Truck, Box Truck, Plow Truck, School Bus, Cargo Van, Boat, etc.
