Price: $6.99
(as of Aug 17, 2024 22:00:19 UTC – Details)
The Cameo Currituck Cold Packs are the perfect cooler accessory to have on your next adventure. They fit into your Currituck Cooler to help keep food and beverages cold without the need for ice. This helps provides better organization and increases the room inside your cooler. The casing is ultra-durable and is designed to fit additional packs, so you can use as many packs as you need. One large cold pack fits in the 50 quart basket, one medium cold pack fits in the 30 quart basket or two medium cold packs fit in the 50 quart basket, and one small cold pack fits the 30 quart basket.
Better Than Ice: Cold packs fit into your Currituck Cooler to keep food and beverages chilled without the need for ice.Fit Type: Universal Fit
Can Be Used with Additional Cold Packs: All Currituck Cold Pack sizes are designed to fit together
Size: Small cold pack measures 6-1/4-inches x 5-3/4-inches
Easy to Use: Place in freezer 24-36 hours prior to use and then put in cooler to substitute for ice
Durable Construction: Constructed for extreme durability
Reusable: Cold packs are reusable and easy to clean
