Price: $119.99
(as of Sep 09, 2024 12:15:13 UTC – Details)
If you struggle with getting good reception in your home, or you’ve moved and you miss your favorite local radio stations, the CC WiFi 3 is the solution! With the CC WiFi 3 you can listen to your favorite radio shows and thousands from around the world with clear reception. With the vast selection of over 25,000 stations on the new CC WiFi 3 you can be assured you will discover radio shows you love. There are thousands of free rock, jazz, news and talk shows to choose from! All you need is a WiFi internet connection. The CC Wifi 3 has a quick command response due to the fast processor. It comes with a 5 volt AC adapter and an included power cord that can be connected to a USB port for power. The WiFi receiving range is the best we have tested because of the included 5dBi external antenna (necessary to prevent WiFi dropouts). Audio is great for a full voice with clarity. If you would like superior audio for music, the CC WiFi 3 has a line-out which can be used for remarkable results with an amplified speaker system. The CC WiFi 3 line-out only works with amplified speakers. The radio has an adjustable equalizer (Line Out and Headphone) for advanced users centered at 105, 300, 850, 2400, and 6800 Hz plus an adjustable 3D setting for depth. Settings can be adjusted to your ear. Audio from the Line Out is equal to or better than any other WiFi radio we have tested. It is a luxury to have an excellent audio source separate from your cell phone… low cost, much less expensive than a year of satellite radio and no monthly fee. The display does scroll the song title and group if this information is provided by the stream. The screen is not capable of displaying advertising… and nobody tracks who you are. If using the radio somewhere besides your home such as an office, RV park, or a hotel there are some important things to know: 1. The network must be broadcast, hidden networks are not supported. 2. If the network requires MAC filtering and does not allow external unidentified devices, this radio will not work in that environment. 3. Their WiFi must support 2.4GHz, 5GHz only will not work. 4. If the network requires browser authentication (a pop up window that requires you to login and enter your name, room, or space number: or a page that requires you to accept the terms and agreement), that is not supported. 5. If the network requires static IPs or specific IP ranges, there are specific instructions in our instruction manual on how to change the IP address and/or range.
Listen to Thousands of Radio Stations from Around the World With Clear Reception – More than 25,000+ internet radio stations categorized by Location, Genre and Most Popular. Discover radio shows you love. Thousands of free rock, jazz, news and talk shows to choose from! All you need is a WiFi internet connection. Add your own favorite stations by submitting a valid URL to Skytune.
Bluetooth receiving included so that you can send audio from a smartphone or tablet to the CC WiFi 3 Internet Radio. A 5dBi external antenna is included for best 2.4 Ghz Wi-Fi reception and distance within your home.
Great Audio With Full Voice Clarity – Includes a line-out which can be used for remarkable results with an amplified speaker system or any AM, FM stereo receiver for superior audio. An adjustable equalizer (Line Out and Headphone) for advanced users centered at 105, 300, 850, 2400 and 6800 Hz plus an adjustable 3D setting for depth. Settings can be adjusted to your ear.
Great Bedside Radio – It’s small and easy to use. Comes with a clock, dual alarm, sleep timer (15, 30, 45, 60, 120, 150, and 180 minutes) and stereo headphone jack. The included large sized remote control gives you quick access to preset stations. Presets: first 10 presets using the remote buttons, 100+ in sequence list.
Additional Features – Adjustable Backlight, 5-volt AC adapter and USB to radio power cord included. Weight: 1 lbs. 2.6 oz. Size: 6.5” W x 3.9” H x 3.9” D. 2 Year limited warranty. U.S. based tech support.
