C. Crane CC Pocket AM FM and NOAA Weather Radio with Clock and Sleep Timer
Price: $74.98 - $64.99
(as of Aug 09, 2024 07:00:23 UTC – Details)
The CC Pocket is very easy to use and has excellent overall performance. It has five easy to use memory buttons and it stands upright for convenience and best audio through the speaker. The sides are rubber coated to provide a firm grip and to help protect the radio if dropped. The Stereo/Mono/Speaker switch allows you to listen to the radio via the built-in speaker while using earphones as an antenna for the FM and NOAA Weather Bands. It is not common for a radio to block a strong signal that overrides a favorite weaker station. The CC Pocket has excellent selectivity while providing maximum sensitivity to weak signal. Standard Features: – Clear, precise and pleasing audio for its size – About 75 hours of play on (2) AA batteries (not included) with earbuds. 25 hrs. using 1.25″, 16ohm, .5W built-in speaker – Premium earbuds included for providing rich lows and crisp highs while listening – Backlight, sleep timer, clock and alarm, removable belt clip (no auto shut-off) – Battery meter, Signal meter, stereo or mono FM reception indicator – Works with rechargeable batteries. C. Crane loves to design radios for the connoisseur but we don’t want to make radios too complex. The CC Pocket has advanced hidden features not normally found on a pocket radio. Pressing the #1 and #5 keys at the same time, while listening to an AM station, disables the display screen. This allows you to reduce noise and improve AM radio reception under some circumstances. Advanced Features: – NOAA Weather Radio with Alert (disables AM/FM radio while activated) – Five memory pages for AM/FM – Selectable frequency or clock display while listening – Beep on or off – 1, 9 or 10 KHz selectable tuning steps – Selectable Narrow or Wide AM filter – Factory reset control Size 2.5″ W x 4.25″ H x 1″ D, Weight: 4 Oz.
AM/FM and NOAA Weather Band Pocket Sized Radio
Excellent selectivity and sensitivity for its size, 5 one touch memory presets
Built in speaker or can be used with included earbuds
Backlight, Sleep timer, Clock and Alarm, Removable belt clip
Runs on (2) AA Batteries
