BUYDEEM G563-A501 Electric Food Steamer for Cooking, 2 Tire Stainless Steel Steamer with Slow Cook Mode, 1500W, 10-Quart, Green
Price: $299.00
(as of Sep 16, 2024 00:45:14 UTC – Details)
4.5 out of 5 stars
531
4.5 out of 5 stars
531
$299.00$299.00 $259.00$259.00
Model
G563-A501 G563 G67US-A503 G67US
Capacity
10 qt 5 qt 14 qt 7 qt
Layers
2 layers 1 layer 2 layers 1 layer
Menu
Steam, Slow cook, Yogurt Steam, Slow cook, Yogurt Manual, Egg, Meat, Seafood, Vegetable, Grains Manual, Egg, Meat, Seafood, Vegetable, Grains
Power
1500W 120V-60Hz 1500W 120V-60Hz 1500W 120V-60Hz 1500W 120V-60Hz
Anti-dry Protection
Pre-set & Timer
Size
335*285*395mm 13.2*11.2*15.6inch 335*285*295mm 13.2*11.2*11.6inch 385*337*423mm 15.2*13.3*16.7inch 385*337*316mm 15.2*13.3*12.4inch
Accessories
Double stewpot, Ceramic plate, Steamer rack, Manual Double stewpot, Ceramic plate, Manual Ceramic plate, Steamer rack, Manual Ceramic plate, Manual
Steam Everything: BUYDEEM G563 is feature-rich, you can use it to steam food, slow cook, make yogurt, defrost food and baby food with ease; just simply touch the control panel to complete all of the above functions. Support pre-set and anti-dry burn protection
Outstanding Performance: This stainless steel steamer has 1500W of power to quickly produce steam in 60 seconds. Excellent sealing creates a micro-pressurized environment inside the steamer to steam your vegetables and seafood.
Just the Right Size: the compact electric steamer doesn’t take up a lot of kitchen space, with 1 tier the size of an A4 sheet of paper; install the 2-tier steamer rack and you’ll have a much higher and wider area for steaming your food, you can even steam a whole fish and a whole chicken without worrying about cutting them off!
Special Slow Cook Mode: With the purchase of this steamer you will also get 2 glass stew pots, which can be used to make soups, yogurt, bird’s nest and porridge etc.
Superior Material: BUYDEEM G563 steamer is made of food-grade stainless steel, and any plastic parts that come into contact with food are BPA-free; the heating chassis is made of higher-grade 316 stainless steel for more stable efficiency.
