Price: $15.99
(as of Sep 06, 2024 15:30:22 UTC – Details)
Visible Fuel Window
Visible fuel window of this butane lighter is easy to check and refill butane in time.
Windproof Strong Flame
Windproof blue flame of gas lighter works well even in windy conditions with a super powerful flame.
Flexible Long Neck
Flexible long neck protects your hands from burning, perfect for the grill, oven, fireplace, camping fire, wood, BBQ.
Put the filling port of the lighter upward, invert the gas canister, and insert the gas canister tip into the filling mouth, usually takes 5-8 seconds to fill.
Turn the adjustment button on the bottom, it’s convenient and safe to adjust the flame height that should be controlled at 1.5-2.0CM.
The bottom of butane lighter sets the hold hole, easy to store, doesn’t take up space.
Package:
1x Butane Lighter
1x User Manual
Warning tips:
*To ensure safety, keep this lighter out of reach of children.
*Please do not point the lighter head towards the face, clothing, other people, flammable fumes, liquids, or explosive substances.
*Do not use a leaking, damaged or malfunctioning lighter. Work only in well-ventilated areas.
* Make sure lighter is completely extinguished after use. Ensure the lighter is completely cool before storing.
*Read and understand refilling instruction before refueling lighter. Refilling incorrectly may result in serious or fatal injury.
Visible Fuel Window Design: (Please note our butane lighter does not include butane due to DOT and USPS Safety Regulations)This butane lighter adopt an upgrade visible window can help you check the remaining butane, no need to worry about when to fill butane any more
Refillable and Adjustable Torch Lighter: Our torch lighter can be refillable with butane for reuse, and you can easily adjust the flame height by the fuel button to meet different needs
Flexible Long Neck 360 Rotation: The lighter with a 360 degree flexible long neck protects you from burning your hand and can be rotated or bend to different angles at will. You can use it in various scenarios like BBQ, grill, fireplace, etc
Windproof and Hanging-able: The windproof function can give you a better experience when using the jet flame lighter outdoors. After using, you can find the hanging hole at the tail of handle for easy storage
Quality Assurance: We strive to provide you the highest quality products and the best service, you own 12 months promised limited, please feel free to contact us if there is any doubt
