BTECH GMRS-V2 5W 200 Fully Customizable Channels GMRS Two-Way Radio. USB-C Charging, IP54 Weatherproof, Repeater Compatible, Dual Band Scanning (VHF/UHF), FM Radio, & NOAA Weather Broadcast Receiver
Price: $64.89
(as of Aug 04, 2024 15:00:26 UTC – Details)
GMRS-V2 5W GMRS radioGMRS-V2 5W GMRS radio
GMRS-V2 GMRS Two Way Radio
Easiest Customizable GMRS Two Way Radio
The GMRS-V2 has received a major chipset revision from our previous groundbreaking GMRS-V1. The GMRS-V2 has 200 completely programmable channels that you can arrange, modify, and use as: GMRS, NOAA, or Scanner channels. You can quickly add or remove multiple GMRS channels to any location, using our quick and easy on-board menus.
5W Maximum Power & Changeable Antenna
The GMRS-V2 has the maximum allowed power output of 5W. The GMRS-V2 uses a standard SMA female antenna, allowing for use with vehicle antennas such as the Nagoya UT-72G for GMRS use.
Dual Watch and Dual PTT
The GMRS-V2 has one built-in receiver that can simultaneously monitor two channels (semi duplex). The radio chassis has two push-to-talk buttons, the upper PTT transmits on the upper display; while the lower PTT transmits to the lower display.
Want to keep it simple? The GMRS-V2 also offers synced display and single PTT modes to simply monitor a single channel as well.
In the Box: GMRS-V2 GMRS Radio 1800mAh Li-ion Battery GMRS Antenna Dual PTT Earpiece CH-8 Desk Charger Charger Adaptor Belt Clip and Wrist Strap User Manual
Waterproof GMRS radioWaterproof GMRS radio
Long Range GMRS RadioLong Range GMRS Radio
USB-C Charging on BL-8USB-C Charging on BL-8
GMRS radio with accessoriesGMRS radio with accessories
IP54 Weather Resistant
Snow, rain, or shine you can feel free to use your GMRS-V2 radio no matter what the weather conditions are. The GMRS-V2 is weather resistant and splash proof.
The GMRS-V2 transmits at the maximum allowed power of 5W for GMRS use. In ideal situations (unobstructed use), it can transmit up 36 miles handheld to handheld, or up to 100 miles with a GMRS repeater.
BTECH BL-8 USB-C Charging
The BL-8 battery now includes USB-C charging, providing users with greater flexibility and convenience in powering their devices. With this feature, you can charge the battery directly using a USB-C cable, or you can still use the CH-8 desktop charger if you prefer.
The USB-C charging feature makes it easy to charge your BL-8 battery on the go, using a power bank or a laptop with a USB-C port. This means you no longer have to rely on the CH-8 desktop charger, which may not always be available or convenient to use.
Kenwood K1 Accessory Compatibility
The GMRS-V2 uses the Kenwood K1 accessory jack, making it compatible with a large amount of speaker mics and accessories. The K1 accessory jack is the most common accessory jack in the radio market. Pair the GMRS-V2 with the QHM22D speaker mic to allow full dual PTT compatibility.
GMRS radio with flashlight GMRS radio with flashlight
Fm radio for gmrs radio walkie talkieFm radio for gmrs radio walkie talkie
Hands free operation GMRS walkie talkieHands free operation GMRS walkie talkie
Pc programmable GMRS radioPc programmable GMRS radio
NOAA Weather Radio, SOS Alarm & Flashlight
Stay prepared! The GMRS-V2 includes a high powered LED flashlight.
The GMRS-V2 also has an SOS alarm mode that allows both onsite and broadcasted alarm modes.
Quickly toggle to hear your local NOAA broadcast and alerts without any additional programming.
FM Radio
The GMRS-V2 includes a built in FM radio. You can still monitor up to two GMRS channels simultaneously and they will interrupt the FM radio when a transmission is received.
VOX Hands Free Operation
Use the radio hands-free with VOX. You can use the included dual PTT earpiece kit or your own preferred accessory to transmit when the radio detects your voice for hands-free operation. It also works with the QHM22 Dual PTT Speaker Mic and the QHM07 Surveillance earpiece kit.
CHIRP Programmable
The GMRS-V2 is ready to go out of the box, but can be customized further with CHIRP support (custom channel names, custom boot up name, and more).
The GMRS-V2 uses the PC03 programming cable (not included). Software is Windows, OS X, and Linux compatible.
Easily create a radio template and copy it to all radios and easily set a similar standard for each group of radio users.
Technical Specifications
Frequency Range GMRS 462.5500 ~ 467.7250 MHz (Rx & Tx) / UHF & VHF (Scanning & Receiver) / FM Radio Memory Channel 200 Channels: Programmable with GMRS, NOAA, or VHF/UHF Scanner Channels Output power 5W/.5W Privacy Tones (PL/DPL) All CTCSS and DCS tones are supported. Accessory Jack K1 Kenwood 2 Pin Jack Additional Features Single/Dual PTT Toggle Modes, Display Sync, Nuisance Channel Scan Skip, SOS Alarm, NOAA Weather Channels, Transmit Time-Out, Busy Channel Lockout, DTMF Keypad, Adjustable Scanning Modes, Dual Watch, Adjustable Squelch Weatherproof Rating IP54 Weather Resistant Chassis Accessories Compatible with all UV-82 and GMRS-V1 Chassis Accessories
GMRS-V2 a better receiver than our imitatorsGMRS-V2 a better receiver than our imitators
GMRS-V2: A Better Receiver than our Imitators!
BTECh Radios Proud to be in the USABTECh Radios Proud to be in the USA BTECH: We are proud to be here in the USA
BTECH radios are designed and supported right here in the USA. A BTECH label means you are getting a radio with real US based support, and development! If you ever have an issue, our team will be prompt, knowledgeable, and supportive to ensure your radio operates exactly as it should.
Unlike our peers we do not take an existing radio off the shelf and simply apply ‘a different firmware’. The GMRS‑V2 was from the ground up – built for GMRS! It takes time to properly build a product dedicated for a specific purpose. A properly designed radio, means that the receiver and transmitter will outperform in clarity, reach, and performance in comparison to those other radios that simply had that magic ‘firmware flash’.
Common Questions and Answers:
Q: What is the charge and usage time? A: The radios will fully charge in 3-4 hours, and the battery will last 18 hours on normal usage. Q: Is it compatible with other walkie talkies? A: Yes, it supports all CTCSS and DCS tones used by other brands and will operate with all FRS/GMRS radios. Q: What is the maximum range? A: Range varies on topography: Repeater Use: Up to 100 miles | Hill to Valley: 36 miles | Open Flat Terrain: 3-5 miles | Urban/Outside Buildings: ~1 mile
467
4.0 out of 5 stars
102
4.3 out of 5 stars
166
479
$64.89$64.89 $109.89$109.89 $219.89$219.89 $154.89$154.89
GMRS Power Output
5W 20W 50W 5W
Waterproof Rating
IP54 IP67 IP67
Channels
200 200 256 180
NOAA Channels
Multiple GMRS Repeater Support
Unlimited (Fully Customizable Channel List) Unlimited (Fully Customizable Channel List) Unlimited (Fully Customizable Channel List) Unlimited (Fully Customizable Channel List)
CTCSS / DCS Tones
390+ 390+ 390+ 390+
Several Accessory and Battery Options
Dual PTT
Fully Modifiable Channel and Scan Lists
USA Designed and Supported
467
467
467
467
467
$64.89$64.89 $64.89$64.89 $64.89$64.89 $64.89$64.89 $64.89$64.89
GMRS Power Output
5W 3W 5W 4W 2.5W
Waterproof Rating
IP54 IP67 – – JIS4
Channels
200 128 250 128 50
NOAA Channels
Unlimited (Fully Customizable Channel List) 4 Sets (Hard loaded) 3 Sets (Hard loaded) – NOT CHIRP COMPATIBLE 1 Set No Repeater Support – NOT CHIRP COMPATIBLE
CTCSS / DCS Tones
390+ 390+ 250+ 390+ 142
Dual PTT
Product Dimensions ‏ : ‎ 2.28 x 1.26 x 4.33 inches; 8 ounces
Item model number ‏ : ‎ GMRS-V2
Batteries ‏ : ‎ 1 Lithium Ion batteries required. (included)
Date First Available ‏ : ‎ April 30, 2022
Manufacturer ‏ : ‎ BTECH
ASIN ‏ : ‎ B09Z1NJ1M3
Country of Origin ‏ : ‎ China
GMRS 2-Way Radios – The GMRS-V2 Features 200 Customizable Channels that can be used for GMRS, NOAA or Scanning. The radio has the ability to scan and check for activity. The GMRS-V2 offers an IP54 weather proof resistant casing.
Customizable – Quickly add any GMRS/NOAA Channels/Scanner Channels to any channel location. GMRS channels are customizable to use up to 5W output and transmit on narrowband or wideband. Customize channel names and more using the free CHIRP programming software
Feature Packed – Nuisance Channel Scan Skip, Display Sync, FM Radio, NOAA Radio, Transmit Time-Out, Busy Channel Lockout, DTMF Keypad, Adjustable Scanning Modes, Dual Watch, Adjustable Squelch
Kit Includes: GMRS-V2 Radio, 1800mAh Battery, V-85 Dual Band Antenna, CH-8 Charger, CH-8 110V Adapter, Earpiece Kit, Wrist Strap, Belt Clip, User Manual
BTECH is proud to be in the USA, which allows you to have the best available local support for any issue that may arise. BTECH only engineers and develops radio products. This brand focus allows you to have the best available radios and accessories with the most features, with real USA warranty and support.
