BTECH ER-V1 Emergency Solar Hand Crank Portable Radio, AM/FM/NOAA/SW Radio Receiver, 5 Ways to Power with 2000mAh Power Bank Phone Charger, USB Charger and LED Flashlight
Price: $54.89 - $12.89
(as of Aug 26, 2024 08:15:09 UTC – Details)
ER-V1 emergency weather radio ER-V1 emergency weather radio
ER-V1 Emergency Solar Hand Crank Radio
The BTECH ER-V1 Emergency Radio is the essential radio you need in the event of emergency or just to take on the go to be prepared for anything life may throw at you. Because the internal receiver chipset of the ER-V1 is manufactured in the USA, this high powered portable radio has radio receiving quality leagues ahead of any similar priced emergency radio. Having an ER-V1 emergency portable radio is a great way to stay informed and connected during an emergency situation. With the ability to tune into a variety of news and weather updates, you can stay informed about what is happening and what actions you may need to take.
Additionally, with a built-in flashlight and the ability to charge other devices, you’ll have a reliable source of information and power when you need it most. Remember to test and familiarize yourself with the radio and its features before an emergency happens, so you are prepared and know how to use it effectively.
The ER-V1 Emergency portable radio has everything you need to be prepared in an emergency:
AM/FM tuning for local and national news and weather updatesNOAA weather band for severe weather event updatesShortwave Radio Reception for ham radio activity monitoring during crisisHand-crank/solar-powered charging for use without electricityBuilt-in LED flashlight for low-light situationsUSB charging port for device chargingDurable and waterproof design with IPX3 weatherproof rating. Use any of 5 methods to keep the ER-V1 radio running during a power outage or other emergency situation, ensuring you always have a way to stay informed and connected.
Hand-crank: power the unit by turning a hand-crank without electricitySolar: charge in direct sunlight, reliable during an emergencyLi-ion battery: recharge via USB, wall adapter, or other power sourceAC/DC: plug into an electrical outlet when availableAAA batteries: convenient when power sources are unavailable, easily replaceable.
What’s in the Box: ER-V1 Portable Emergency Radio USB Charging cable User Manual
BTECH ER-V1 Solar powered emergency radioBTECH ER-V1 Solar powered emergency radio
Emergency RadioEmergency Radio
BTECH ER-V1 35 lumen flashlight and emergency alarmBTECH ER-V1 35 lumen flashlight and emergency alarm
BTECH ER-V1 held in handsBTECH ER-V1 held in hands
Chipset Manufactured in the USA
The Internal radio Receiver Chipset of the ER-V1 is manufactured in the USA, providing the ER-V1 with the highest receiving quality available
LED Flashlight and Emergency Siren
The 35 lumen flashlight will provide a bright light source in case of power outages or other low-light situations, while the emergency siren can be used to signal for help in case of emergency.
AM/FM/NOAA/SW Radio
The AM and FM bands allow you to tune into a wide range of local and national news and music stations, while the NOAA band allows you to receive weather alerts and updates from the National Oceanic and Atmospheric Administration. The SW (shortwave) band allows you to receive international news and information from stations around the world.
ER-V1 on car trunk ER-V1 on car trunk
5 ways to power ER-V1: handcrank, solar, ac/dc, li-ion, AAA battery5 ways to power ER-V1: handcrank, solar, ac/dc, li-ion, AAA battery
BTECH ER-V1 Emergency radio sitting on a tableBTECH ER-V1 Emergency radio sitting on a table
NOAA Radio
NOAA radio has two modes. One mode will constantly receive any NOAA traffic from the 7 NOAA weather bands, this helps the consumer find which NOAA station is closest in their area as well as hearing standard weather forecasts. The NOAA Alert mode will only receive traffic if a severe NOAA alert is broadcasted.
5 Ways to Power your ER-V1
The ability to power the radio in multiple ways means that you will always have a way to stay informed and connected, even in the event of a power outage or other emergency situation.
Charge your Cell Phone or favorite USB devices
The ER-V1’s powered USB port allows you to charge USB-powered devices anywhere, providing a convenient way to stay connected during emergencies.
Technical Specs
Battery Power 3.7V / 2000 mA h rechargeable lithium battery (integrated) or 3 x AAA batteries Flashlight 35 lumens LED Flashlight Siren 125 dB Radio Bands AM:520 KHz to 1710 KHz, FM: 87.5 MHz to 108 MHz, Weather Band: 162.400 to 162.550 MHz, SW: 5.950MHz to 21.850 MHz, SW1 :5.950 MHz to 6.200 MHz, SW2: 7.100 MHz to 7.300MHz, SW3: 9.500 MHz to 9.90MHz, SW4: 11.650 MHz to 12.050 MHz, SW5: 13.600MHz to 13.800MHz, SW6: 15.100 MHz to 15.600 MHz, SW7 : 17.500MHz to 17.900MHz, SW8: 21.450 MHz to 21.850 MHz Dimensions 6.0″ x 3.5″ x 2.0″ Weight 15 oz Additional Features AM/FM/NOAA/SW, LCD Display, Flashlight, Emergency Siren, Clock, Solar charge, Hand Crank, Telescopic Antenna, Mini USB input port, USB charging port, Headphone Jack Output Ports Powered USB-A Charge Port & 3.5MM Line-Out (connect headphones or speaker),
ER-V1 Side profile imageER-V1 Side profile image
BTECh Radios Proud to be in the USABTECh Radios Proud to be in the USA BTECH: We are proud to be here in the USA
BTECH radios are designed and supported right here in the USA. A BTECH label means you are getting a radio with real US-based support, and development! If you ever have an issue, our team will be prompt, knowledgeable, and supportive to ensure your radio operates exactly as it should.
FAQs
Q: What are the dimensions?
A: The ER-V1 is 6.0” x 3.5” x 2.0” and weighs 15 oz.
Q: What are the frequencies that can be received?
A: AM, FM, NOAA, and SW(Shortwave) frequencies can all be received.
Q: What is Shortwave Radio?
A: Shortwave radio operates on frequencies between 1.6 and 30 MHz, which can bounce off the ionosphere and travel long distances. It’s used for international broadcasting, emergency communication, and amateur radio.
[MADE IN THE USA] The ER-V1’s internal receiver chipset is manufactured in the USA, ensuring the highest quality of radio signal reception you can find for a device priced under $100. The US-made chipset is built with the latest technology, making it more efficient at receiving radio signals than its counterparts manufactured elsewhere. With the ER-V1, you can be sure to receive the most accurate and reliable information during an emergency.
[5 WAYS TO POWER] The ER-V1 offers five different ways to power the device, so you can be prepared for any situation. You can power the radio through AC/DC, solar, hand crank, 2000mAh battery, or AAA battery. The 2000mAh power bank is a particularly useful feature, as it allows you to charge your phone during emergencies. Having multiple power options ensures that you won’t be stranded without communication or power when you need it most.
[PORTABLE RADIO] The ER-V1 is a portable radio that can connect to AM/FM/NOAA/SW radio signals, giving you access to up-to-date emergency forecasts and news broadcasts. With this feature, you can stay informed during emergencies or natural disasters, even if you don’t have access to the internet or other means of communication. The portability of the radio also makes it an ideal companion for outdoor activities, such as camping or hiking.
[FLASHLIGHT AND WEATHERPROOF] The ER-V1 is designed with durability in mind. The radio is rated IPX3 weather-resistant, meaning that it can withstand exposure to water, making it ideal for use during outdoor activities or emergencies. Additionally, the radio comes equipped with a 35-lumen LED flashlight, which is bright enough to light your path and alert others to your presence. This flashlight feature ensures that you are not left in the dark during emergencies, giving you a sense of security and comfort.
BTECH is proud to be in the USA, which allows you to have the best available local support for any issue that may arise. BTECH only engineers and develops radio products. This brand focus allows you to have the best available radios and accessories with the most features, with real USA warranty and support.
