BLUETTI Portable Power Station AC200P, 2000Wh LiFePO4 Battery Backup w/ 6 2000W AC Outlets (4800W Peak), Solar Generator for Outdoor Camping, RV Travel, Home Use (Solar Panel Not Included)
Price: $1,099.99
(as of Aug 21, 2024 05:30:33 UTC – Details)
BLUETTI LOGOBLUETTI LOGO
AC200P 970×600AC200P 970×600
2000Wh 2000W Power for Indoor and Outdoor 970x6002000Wh 2000W Power for Indoor and Outdoor 970x600
TROLLEY CART A+TROLLEY CART A+
BLUETTI / ABOUT US
Before BLUETTI, we spent over a decade heavily involved in the new energy industry. With rich industry experience, an innovative R&D team, and advanced technology, BLUETTI has started its journey in 2011 as a segment brand focusing on portable energy storage solutions. Now, as the top tier of the portable power industry, BLUETTI becomes a firm backup to support our beloved customers to explore more in life, both indoor and outdoor.
2000Wh/2000W, All in One, Do it All.
Home Use: Phone, Laptop, TV, Coffee Maker, Hair Dryer, Refrigerator…Workshop: Circular Saw, Electric Drill, Heat Air Gun, Air Conditioner…Camping/Van Life: Electric Grill, Ice Cooler, Projector, Drone, Camera…
BLUETTI AC200P Premium LiFePO4 Battery TechnologyBLUETTI AC200P Premium LiFePO4 Battery Technology
BLUETTI AC200P ECO Power Saving ModeBLUETTI AC200P ECO Power Saving Mode
BLUETTI AC200P Get Recharged by Solar and AC Power SimultaneouslyBLUETTI AC200P Get Recharged by Solar and AC Power Simultaneously
BLUETTI AC200P Dual AC Adapter Charging with a Higher SpeedBLUETTI AC200P Dual AC Adapter Charging with a Higher Speed
LiFePO4 Battery Chemistry + Premium BMS
3500+ Full Life Cycles to 80%, durable & secure3-6 times longer than others’ 500-800 Life CyclesBuilt-in Battery Management System for multi-level protection
Tips: Charging from 50% to 100% only counts as 1/2 life cycle.
Touchable Screen + ECO Mode
Informative & Smart touchable LCD screenAC power will shut down when the output load keeps under 50W after 4 hoursSave up to 50% of unwanted power waste
Tips: You may turn on/off the ECO Mode on the LCD screen.
700W PV+500W AC for Fast Charge
AC200P comes with two input ports for faster recharging700W Max. solar input combined with 500W AC adapter input to get the total 1200W powerWith 1200W input, fully recharge the AC200P under 2.5 hours!
Dual AC Adapters w/ 1000W Input
Normal Speed: With one AC adapter (500W), get fully recharged in 4.5-5 hours2 x Speed: With dual AC adapters (1000W total), get fully recharged under 3 hours
Note: The 2nd adapter & cable are sold separately.
Technical Specifications
Battery Capacity 2000Wh / 40,000mAh Battery Cell Type LiFePO4 (3500+ Life Cycles) Dimensions 16.5 x 11 x 15.2 in. / 420 x 280 x 386 mm Weight 60.6 lb / 27.5 kg Working Temperature 32°F-104°F / 0°C-40°C Storage Temperature 14°F-113°F / -10°C-45°C 6*AC Outputs 120V, 2000W (Peak 4800W), Pure Sine Wave 1*Type-C 60W Max (5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3A ) 4*USB-A 5V/3A 4*DC Outputs Regulated: 1 x 12V/25A (RV Port), 1 x 12V/10A (Car Port), 2 x 12V/3A 2*Wireless Charging Pad 15W Max. (for each) AC Charging Input 500W (1 x adapter) / 1000W (2 x adapters) Solar Input OCV 35-150V / 700W Max. / 12A Max. Car Input 12V/24V
4.5 out of 5 stars
28
316
4.6 out of 5 stars
104
Battery Capacity(power station)
716Wh 716Wh 716Wh 500Wh
Max Output(power station)
700W 700W 700W 300W
Number of Output ports
12 12 / 11
Phone (2815mAh)
50+ charges 50+ charges / 39 charges
Laptop (60Wh)
9-10 charges 9-10 charges / 7-8 charges
Mini Fridge (50W)
12 Hrs 12 Hrs / 8 Hrs
Coffee Maker (600W)
60 Mins 60 Mins / /
[Power Monster] – With the remarkable 2000Wh of capacity and a strong 2000W inverter, this AC200P power station can power 99% of home devices, giving you confidence in any emergency.
[3500+ Life Cycles to 80%] – The ultra-safe LiFePO4 battery cells and premium BMS tech offer multiple protections to your AC200P, making it a reliable power backup that can last longer than a decade.
[Efficient Recharging Rate] – AC200P supports up to 700W solar and 500W AC input, allowing you to fully recharge it in 2.5 hours by solar+AC or dual AC charging.
[17 Versatile Outlets] – 6 AC ports, standard USB-A/Type-C/Car port plus 2 wireless charging pads always can service your various needs, while a 12V/25A DC port will power your DIY work.
[What You Get] – BLUETTI AC200P portable power station, AC adapter, solar/car charging cable, XT90-aviation cable, user manual, 24-month warranty, and friendly local customer service.
