BESTEK 300W Power Inverter DC 12V to 110V AC Car Inverter with 4.2A Dual USB Car Adapter
Price: $26.98
(as of Aug 20, 2024 04:30:13 UTC – Details)
300w power inverter (red)300w power inverter (red)
60 Month60 Month
Quick USB ChargingQuick USB Charging
Widely CompatibilityWidely Compatibility
USA BASED SUPPORT
BESTEK provide 5-year product repair policy and our fast-response service will solve all your inquiry and problem, please don’t hesitate to ask Amazon.
2 USB-A 2AC PLUG
2 USB-A provide a stable 0-2.4A2 AC outlet, power inverter makes the DC 12V step-up through the transformer, and then converters to AC110V, 60Hz correction wave output.
Great suitable for electric device in the car, for iPhone, laptop, breast pump, CPAPmachine, nebullizer, game console etc. The input voltage is 12V, when the AC output is overload of 350W to 400W, the loading time of 300W to 330W is more than 60 seconds, and the loading time of 330W to 360W is more than 20 senconds.
redred
bestekbestek BESTEK Advantage
America’s leading power inverter brand. Provides 300 watts continuous DC to AC power and 700 watts of peak power
BESTEK 300W Car Power Inverter (Red)
BESTEK Power Inverter with 2 USB ports and 2 AC outlet, only for DC 12V and Car, not applied for DC 24V and airplane use. For charging your iPad, please use the 2.1A USB port and keep the other USB port free. It’s normal for the inverter to become warm to the touch while you are using it, avoid placing the inverter in direct sunlight or next to heat-sensitive materials. Do not use to power high power electric devices such as hair dryers, electric heaters, which might blow a fuse.
Isolation Voltage Protection Dual-USB 4.2A Output Multi-Protection Aluminum Alloy Housing Durable Cigarette Lighter Top Speed Charging
Aluminium Alloy HousingAluminium Alloy Housing
Smart Cooling FanSmart Cooling Fan
Isolation Voltage ProtectionIsolation Voltage Protection
BESTEK power inverter outshell is made of Aluminium alloy, solid and durable,can stand up to all kinds of severe environment, protect the internal components.
Smart Cooling Fan
Smart cooling fan system makes the car power inverter very silent when operating,and the fan runs faster when the device gets warmer or output power exceeds 70W.
Safe charging design provides protection against, overheating, under and over voltage charging, short circuiting, overloads, and overcharging.
Quick USB Charging
With 2 Smart USB charging port, can intelligently detect your devices and deliver best matched charging current to get fast charging speed.Auto 0-2.4A each port, total 4.8A output.
Durable Cigarette LighterDurable Cigarette Lighter
cigarette lightercigarette lighter
Power On LED Strip LightsPower On LED Strip Lights
BESTEK AdvantageBESTEK Advantage
The lighter socket is resistant to up to 5000 times of insertion and extraction.Enjoy a safe,reliable charger on the go.Secure plug-in buckle design with stable current, and built-in usb charging ports.
Top Speed Charging
Made of high quality materials which provides high-speed charging from your car. 24 inch cigarette lighter plug makes the power inverter can be plugged into almost any vehicle.
It can power on your LED Lights anywhere for Christmas and other festivals to create a great atmosphere.
BESTEK Advantage
America’s leading power inverter brand. Provides 300 watts continuous DC to AC power and 700 watts of peak power.
4.5 out of 5 stars
5,223
1,482
4.5 out of 5 stars
2,883
588
4.5 out of 5 stars
9,855
4,371
Color
Black Red Red Red Blue Black and silver
Power
300W 300W 500W 300W 150W 75W
isolation voltage protection
USB Port
4.2A Dual USB 4.2A Dual USB 4.2A Dual USB 4.8A Dual USB 4.2A Dual USB 3.1A Dual USB
Material
Aluminum Alloy Housing Aluminum Alloy Housing Aluminum Alloy Housing Aluminum Alloy Housing Aluminum Alloy Housing Aluminum Alloy Housing
Speed charging
Dimension
8.1 x 5.3 x 2.6 inches 8.1 x 5.3 x 2.6 inch 8.7 x 4.3 x 2.4 inches 7.3 x4.3 x 2.5 inches 5.0 x 4.0 x 2.0 inches 5.5 x 2.4 x 1.6 inches
Feature
Smart cooling fan, ETL listed Smart Cooling fan Smart cooling fan Smart cooling fan Smart cooling fan, ETL listed Smart cooling fan, ETL listed
BESTEK Advantage: America’s leading power inverter brand. Provides 300 Watts continuous DC to AC power and 700 Watts instantaneous power, featuring 2 AC outlets and 2 USB ports
Fast Charging: two 110V AC outlets for charging larger devices such as laptops and tablets, 2 USB charging ports (0-2.4A) for powering USB compatible devices, a good choice as requisite car accessories
Ultra Compact and Lightweight: iPhone-sized design ideal for use on vacations, work trips, and camping. 24 inch cigarette lighter plug makes the power inverter can be plugged into almost any vehicle
Multi-Protection: built-in 40 amps fuse to protect your device. Safe charging design provides protection against, overheating, under and over voltage charging, short circuiting
Durable metal housing provides advanced protection from drops and bumps.Smart cooling fan system makes the car power inverter very silent when operating,and the fan runs faster when the device gets warmer or output power exceeds 70W. 60-Months Warranty
【60 Months Warranty】: ETL certified products to ensure safety and quality. If you have any questions or are dissatisfied with your purchase, BESTEK will provide 24 hours x 7 days technical and friendly customer service support, as well as a 60-month product replacement warranty.
