Bear DFH-B20J1 Smart Self Heated Lunch Box, Mini Hot Pot, Leakproof Plug-in Lunch Box with Keep Warm Function, Blue, 2L
Price: $79.90
(as of Aug 19, 2024 17:45:31 UTC – Details)
11
Preset timer& power
9.5 hours preset timer, adjust cooking time and power(100-600W), meet all your need.
3 Inner Container
2L capicity self heated lunch box including 3 inner container of 1L, 0.75L, 0.25L. Flexible of using for your meals. The inner steel and outer plastic, make it safer.
Vacuum Pump
Vacuum sealed make the food keep fresher and the heat preservation more durable.
Multi-functional Rice Porridge Hot pot Keep warm Reheat Steam Boil …
Multi-use Base
hot pothot pot
noodles cookernoodles cooker
porridgeporridge
food warmerfood warmer
Hotpot Pot
Noodles Cooker
Porridge Maker
Food Warmer
layerlayer
snapsnap
bracketbracket
Three-layer Design
The outer layer of the lunch box is made of plastic to prevent hot hands; the middle layer is hollow to isolate heat; the inner layer of stainless steel retains heat and fresh flavor
Effort-saving Buckle
The lunch box uses a labor-saving buckle, fastening the firm and easy to open
Stainless Steel Accessories
The parts of the lunch box in contact with food are stainless steel, safe and healthy; triangular bracket can isolate the base and the inner liner, reducing noise and stability
4.1 out of 5 stars
50
$79.90$79.90 $59.90$59.90
Model
DFH-B20J1 DFH-B15Q1
Capacity
2L 1.5L
Heating Method
Plug in Plug in
Power
600W 120V-60Hz 350W 120V-60Hz
Weight
1.88kg/4.14lb 1.36kg/2.99lb
Function
Rice Cooking, Porridge, Reheat, Hot Pot, Keep Warm Rice Cooking, Food Cooking, Reheat, Keep Warm
Size
180*164*239mm 252*145*172mm
More Than Just Lunch Box: Bear electric lunch box has five functions of Rice, Porridge, Reheat, Hot Pot, Warm, it can also become your small hot pot ,ramen pot, food steamer, rice cooker etc.
Portable Size: Small size self heting lunch box suitable for office, truck, outdoor camping, etc.; It contains 1L, 0.75L, 0.25L stainless steel inner pot, giving you more cooking space
Smart Adjustment: This self cooking lunchbox supports 9.5 hours preset, cooking time (timer) and power can be adjusted; 600w power will not waste a lot of your cooking time
Fresh Food for Longer: Each electric lunch box comes with a vacuum pump; using the vacuum pump and the double-layer silicone lid inside the package, you can keep the food fresher for longer
What You Get: Bear electric lunch box, vacuum pump, power cord (Not a battery-operated lunchbox) , user manual, our 1-year friendly customer service. (The power cord is usually placed inside the inner pot of the electric lunch box. )
