Price: $399.00 - $339.04
(as of Sep 29, 2024 18:30:18 UTC – Details)
Upgrade your bike and enjoy cycling like never before!
BAOSHISHAN E-bike Converter is not like the e-bike conversion kits on the market that the installation process is complex.
It’s tool-free installation, smooth assistance at a healthy ride, and affordable.
Quick Installation
No extra tools, no wheels to remove, no mid-drive to replace. With just a hex wrench included, you can transform a bike into an electric-assisted bike in less than 3 minutes.
Record Every Trip
You can search for our app in mainstream stores and use the app to connect with our devices. Get power, boost level, and ride data.
Check your seatpost first! Required length of exposed seatpost
Please make sure that at least 6 inches of the exposed seatpost of the daily position is available to install the booster, otherwise it may will affect the riding position.
Required height of exposed seatpost
Make sure the seatpost clamp is no more than 0.8 inches above the top of the rear wheel, or it might not fit the booster properly.
Specifications
Net Weight 4.4lb Battery 18V/10AH Motor 200W Maximum Speed 15.5Mph (25km/h) Range 31Miles (full charge, HALF assistance, actual range may vary based on terrain and load) Charging Time 5h Suitable Road Surfaces City paved roads, gravel roads Suitable Tire Widths Mountain Bike: 1.5/1.75 /1.95 /2.15 inch Road Bike: 25C/28C/35C /38C Suitable Seat Post Sizes 25.4/27.2/28.6/30.4/30.8/31.6 mm Product Dimensions 305mm x 100mm x 117mm Outer Packaging Dimensions 370mm x 180mm x 128mm Seat Post Compatible Shapes Round Seat Post Compatible Diameter Φ25.4~31.6mm
Is it waterproof? Can I use it in the rain?
No, It’s not waterproof.
When passing through water sections during cycling, the reduced friction between the wheels and the power assist wheel may lead to a decrease or loss of assistance.
How does the pedal assist work?
When the bicycle speed exceeds 5 km/h,the pedal assis automatically engages. At this point, lightly pedal, and it can help you maintain the riding speed. Mark sure the device and the rear wheels bite tightly.
How do I control it to slow down?
To decelerate, there are two ways:
– Reduce pedaling frequency.
– Squeeze the brakes.
Compatible with round seatposts only. Exposed seatpost length must be greater than 6 inches. Seat tube clamp height must not exceed 4/5 inch above the highest point of the rear wheel.
30s Tool-Free Installation: Converts your bike into an electric bike in 30s without disassembly and extra tools.
Excellent compatibility: Suitable for any bicycle with Round Seat Post Φ25.4~31.6mm. Compatible with road bike tire width: 1.5/1.75/1.95/2.15inch and mountain bike tire model: 25C/28C/35C/38C.
Up To 31 Miles Range: On a full charge, it could drive a distance of up to 31 miles (50km) in HALF boost mode. Actual range may vary based on terrain and load.
APP Control: You can check the real-time power level of the booster and switch the booster mode through the app on your phone, and it also shows the real-time data of your riding.
[FRIENDLY SUPPORT] BAOSHISHAN take the responsibility of 2-year warranty and lifetime after-sales support.
