Price: $18.85
(as of Sep 19, 2024 22:45:33 UTC – Details)
Thank you for choosing AUCARAUTO! We strive to provide you with high-quality products and excellent services.
Easy Installation:
Find a flat surface (parallel or perpendicular to the ground) for mounting the camera, then secure the nuts and bolts in place.Mount the camera on the panel and route the wire inside (DO NOT pinch the wire/cable when routing it, as pinched wire will damage the camera). If needed, drill a hole to allow the wire to go through.Connect the red power wire of the backup camera to the power of the reversing light. Connect the black wire to GND. Apply electrical tape to the joint of the red power wires and RCA wires, and use zip ties to fasten the wire on your vehicle.Connect the 32.8ft extension wire of the backup camera to the Monitor/Screen/Display/head unit of the vehicle (Monitor/Screen/Display/Radio not included). If you are connecting this backup camera to a factory radio, please separately order a suitable harness and programmer to complete the installation, as different radios require different harnesses and programmers to work together.For camera connection, please connect the camera’s male plug to the female connector of the extension wire/cable, ensuring that the arrows align. Also, make sure to push the camera’s male plug tightly into the female connector of the extension wire.If your head unit has a reverse triggering wire, usually a pink-colored wire, please locate it and connect it with the triggering wire of the extension wire (a small, short red wire next to the RCA/AV connector). If your head unit does not have a trigger wire, then there is no need to use the B trigger wire.Start the vehicle and put it in reverse to test the camera.
Notice:
The camera and extension cable are specialized. Please do not use other 4 PIN connectors to connect to this camera, as it may damage the camera.Before routing the 32.8ft extension wire from back to front, please test the backup camera.If there is no image on the screen, apart from checking the camera, please also check the display settings. You can use another device with an RCA connector, such as a TV, to check if the camera is working.If the image on the screen is blurry, flickering, or has horizontal or vertical stripes, please check all your power and video connections. You can try using a different ground point (iron part) and wrap the power and video plugs with electrical tape to insulate them from interference. If the issue persists, please consider ordering a 12V DC power adapter filter rectifier to solve it, especially if you have a Dodge, AUDI, BMW, or Mercedes Benz vehicle.
How to achieve different effects or mounting styles by keeping or cutting the coil.
AUCARAUTO K21 Reverse camera with 3 color small wires/Loops (White, Green and Blue).
If you require a rear view camera with hanging mounting installation, please keep the blue wire/loop. Hanging mounting is a great design for sedans and SUVs.If you require a rear view camera with sitting mounting installation, simply cut the blue loop. Sitting mounting is a great design for pickup trucks, RVs, and vans.If you need the guide line, please keep the green wire/loop. If you do not need it, simply cut it.If you require a front view camera or side view camera, please cut the white wire/loop.If you need a front view camera without guide lines, please cut both the white and green wire/loop.For a side view camera, it can ONLY be installed on a horizontal surface (under the left or right mirror), NOT on a round, slanted, or perpendicular surface. To look backward, keep the white wire/loop; to look forward, cut the white wire/loop.If the image has not changed after cutting the wires, please restart your car after cutting the cable to enable the ability to switch the display effect.
170° Wide Angle View Night Vision Reverse Camera
The AUCARAUTO K21 reverse camera features a 170-degree wide horizontal view angle lens, providing a significantly wider range of visibility compared to other cameras with smaller angle lenses such as 149° or 120°. With its wide-angle lens, you will be able to see much more than what is typically visible in the rearview mirror. This enhanced visibility helps greatly in reducing blind zone accidents.
High Resolution and Great Night Vision
The AUCARAUTO K21 backup camera is equipped with a built-in digital high-definition image processor. It has a maximum resolution of 1280*720 pixels and an effective resolution of 960*576 pixels at 25 frames per second (fps). The camera features a 6-layer full HD glass lens with an F1.8 large aperture, ensuring excellent sharpness and clarity in both day and night conditions. It also supports impressive night vision capabilities, with a minimum illumination of 0.01Lux and a TVL (TV lines) rating of up to 800TVL, providing a clear view even in low-light situations.
Excellent Waterproof Performance
The AUCARAUTO K21 waterproof backup camera is designed using a fully sealed glue filling craft, ensuring its ability to function properly even under challenging conditions. This design feature provides protection against water and mist, giving you peace of mind that the camera will not be affected by moisture. You can rely on the camera to maintain its performance and functionality regardless of the weather or environmental conditions.
Packing Details
1 x AUCARAUTO K21 Backup Camera; 1 x 32.8ft/10M Extension Wire/Cable; 1x 304 Stainless Nut; 1 x Double Tape; 1 x Electrical Tape; 1 x Panel Remover; 3 x Zip Ties; 1 x User Manual; 1 x Gift Box.
【Durable & Waterproof Night Vision Camera】Back up camera is made by durable metal housing and fully sealed glue filling with IP69K waterproof, you absolutely no need to worry about water, fog or mist inside.
【HD Image Rear View Camera】Rear view camera with a latest HD 800TVL and 0.01Lux low illumination level image sensor and 6 glass lenses offers 100% true color reproduction. Extra-wide 170-degree viewing angle lens reduces blind spots and provides excellent visibility.
【Versatile Reverse Camera】Small size design reverse camera with three switcher cables can be used as a rear/front, or side view camera. It offers options to switch mirror/positive image, enable/disable guide lines, and adjust the mounting position.
【Universal Backup Camera】Backup camera with 32.8ft RCA video cable, suit for most types of DC 12-24V different length vehicles. Such as Cars, SUVs, Pickup Trucks, RVs, etc. It will work well with your radio, monitor, DVD player or screen has the RCA connector.
【Why It Doesn’t Work】Note! This camera is for CVBS/CCD monitors only, not for AHD vehicles; The camera and extension cables are proprietary, please replace the original camera kit completely when installing; If the image is blurry, please consider using a 12V DC power adapter filter rectifier to solve the problem, especially for Dodge, Audi, BMW or Benz vehicles! Please test the camera before installation, if it is not working properly, please contact to replacement.
