Backup Camera System with 9” Quad Split 1080P Monitor for RV Trailer Semi Truck Camper Bus & 4 AHD Rear Side View Camera with DVR Record Function Night Vision IP69 Waterproof Avoid Blind Spot DOUXURY
Price: $339.99
(as of Jul 28, 2024 03:15:23 UTC – Details)
DOUXURY Wireless Backup System for Bus, Truck, Trailer, Box, RV, Trailer, Tractor, the 5th Wheel
Why is the DOUXURY brand worth your choice?
▪ Quality Guarantee: We promise to replace the damaged part for free.
▪ Professional Service and tech Support: Have any question? Send an e-mail, get help from our technology support team.
Notice before order
—the front view camera and the 2 side view cameras are non-mirror-image camera.
—the rear view camera is mirror-image camera.
So if you want them all to be non-mirror-image camera or mirror-image camera, just contact me after order, I will change the camera according to your needs.
How to Install?
All necessary accessories are included. Install the system according to the user manual book, and each line is labeled with a label explaining what it should be connected to.
Tips:
▪ Read the user manual before installing and using.
▪ Trigger wires do not have to be connected.
Specification:
Rear & Front View Cameras:
▪ Waterproof Level: IP69
▪ IR infrared led light: 18 pcs.
▪ Power Supply: 12-24V DC.
Side View Cameras:
▪ Waterproof Level: IP67
▪ IR infrared led light: 10 pcs.
▪ Lens Angle: 120°.
9 Inch Quad View Monitor:
▪ Display Resolution: 800*480.
▪ DVR image: 640*480 pixels.
▪ Power supply: DC-12V-24V.
What you can get:
▪ 9 Inch LCD Monitor x 1.
▪ Front View Camera x 1.
▪ Rear View Camera x 1.
▪ Side View Cameras x 2.
▪ 16ft AV Cable x 1.
▪ 33ft AV Cable x 2.
▪ 66ft AV Cable x 1.
▪ All Necessary Accessories x 1.
Flexible Vehicle Compatibility: Power supply of 12-24V DC needed can be found in a wide variety of large vehicle as semi-trailer, box, truck, the 5th wheel, trailer, bus, camper.
Built-in DVR Recording Function: 9” large LCD monitor built in DVR recording function. Support to local playback and looping record, you can find the video easily in the monitor.
4 Split 1080p Monitor: Backup camera system supports quad view display, 4 video inputs from a front rear and 2 side view cameras can be shown on screen. Avoid Blind Spot. 1, 2, 5 minutes off display to protect the screen.
IP69 Waterproof Level: Excellent sealing technology, IP69 waterproof level. Safe to use in sunny or rainy days. Withstand extreme temperatures from -4℉~149℉.
Easy to Install: Wired rv camera system without any signal problem. One power cord supports the whole system. The camera only needs to connect the extension cable from the monitor.
Night Vision & Wide View Angle: Sharp clear night vision with infrared LED lights function, 170-degree wide viewing angle removes blind spots and safer driving.
