Backup Camera System VMS 1080P high definition Wired 2 Videos 7″ Wide in-Plane Switching Monitor Night Vision Backup Camera for Trucks Buses Recreational Vehicles Vans, All Heavy Duty Vehicles
Price: $159.99
(as of Sep 07, 2024 22:30:14 UTC – Details)
VECLESUS VMS 1080P HD Vehicle Backup Camera System
new vms infonew vms info
Product Information:
Panel Size: 7″ TFT LCD digital panelCamera Sensor: 1/3″ Sharp color CCDResolution: 800*RGB*480Brightness: 300cd/㎡Screen Mode: 16:9Video System: NTSC / PAL auto detectionBuilt-in speaker, removable wide sunshadeHorizontal Viewing Angle: 100°Diagonal Viewing Angle: 120°Camera Waterproof Rating: IP68Power Supply: DC 9~36VOverall Dimensions: 5.31″(H) x 8.27″(L) x 2.95″(D)OSD menu, Remote ControlVideo Input: CH1, CH2, 1 Video inputThe length of power cord on the monitor and camera is shown in the figure below:
Multiple Function Mounting Methods
backup camerabackup camera
IP68 Waterproof
Over 12 hours immersion test.High quality waterproof treatments connector.Works perfectly in snow, sleet or rain.
Superior IR Night Vision
Built-in high sensitive infrared night vision chip, super night vision.18 infrared night vision led lights.Automatically turn on infrared night vision at night.
Note: The camera lights are infrared LED it won’t be light up at the night.
Multiple Mounting Methods
Up to three mounting brackets.Upgraded suction cup holder for a stronger suction on thewindshield.
More Details
angle 120angle 120
Wide Angle
Diagonal Viewing Wide Angle 120°
Nomal/Mirror/Flips Mode
Support normal/mirror and Flip mode, not only can be used as a backup camera but also can be installed in the front of your vehicle.
Ajustable Parking Line
The parking line can be adjusted ON/OFF for many purposes, it depends.
VECLESUS VMS Connection Diagram and Package Content
VMS-CONVMS-CON
Tips:
Before installing, please refer to the wiring diagram above and read the user manual carefully in the package.We offer a install video, you can search the text “VECLESUS VMS” to get it on YouTube.
Note:
Although this product is a one-to-one backup camera kit, the power cord is still equipped with two signal input 4-PIN connectors. If you need to use two cameras, please purchase our extension cord and the corresponding camera VC2(Asin: B07JQFDVFR) or VC3(Asin: B08C4V84D1).In addition, generally, the spare AV input port can also be used as channel CH3 by connecting the AV-in cord.This kit is powered by the power supply at fuse box in your vehicle cab, please find out the continuous power supply and reversing power supply with the test pencil or multimeter, then connect the red wire of the power cord to it and the black wire to the GND or iron part, green wire to reversing power supply If you need the system for reversing only, please connect the camera to the CH2 and connect the green reversing wire to the reversing circuit. If you need the system continuous on when driving or parking, connecting the camera to CH1 and ignore the green reversing wire!
FAQ:
Will I be able to install this camera system myself?
Many people do have the handiness to install our systems without having to hire assistance. Otherwise we recommend professional installation as they can let the system is installed correctly.
How do the system receives power?
This system can be worked in 9-36V, it receives power straight from the vehicle’s fuse box.
4.1 out of 5 stars
155
45
4.2 out of 5 stars
380
45
4.1 out of 5 stars
30
4.1 out of 5 stars
703
$29.99$29.99 $109.99$109.99 $29.99$29.99 $109.99$109.99 $89.99$89.99 $47.99$47.99
Wireless or Wired
Wireless Wired Wired Wireless Wired Wired
Night Vision
Infrared Night Vision Infrared Night Vision Infrared Night Vision Infrared Night Vision Infrared Night Vision Infrared Night Vision
Monitor Mount Position
Dashboard or windshield Dashboard or windshield Dashboard or windshield Dashboard or windshield Dashboard or windshield Dashboard or windshield
Monitor Size
4.3〞 LCD 7〞 LCD 4.3〞 IPS 7〞 IPS 5〞 LCD 4.3〞 LCD
Adjustable Parking Lines
Mirror/Normal Image Option
Waterproof Rating
IP 68 IP 68 IP 68 IP 69K IP 68 IP 68
The Length of Extension Cable
/ 66ft+33ft 33ft 66ft(20m) stable long distance transmission 49.2ft 33ft
Supports Several Video Inputs
1 2 1 1 3 1
▶For Large Vehicles Parking Safety – Comes with a 66ft(20M) extension video cord, widely applicable to all kinds of medium or large vehicles, can work perfectly on wide voltage 9~36V, suitable for heavy-duty and long vehicles, such as Recreational Vehicles, motorhome, bus, cargo van, box truck, flatbed truck, bucket truck, tractor and school bus, etc. NOTE: For trailers, we recommend buying VECLESUS trailer backup camera system VMST(which include trailer kit)
▶Easy to Install – This backup camera system powered by fuse box, connected the red to ACC(9-36V), the black connect the Metal (Ground), the green connect the reverse gear circuit as a trigger power, monitor and backup camera will automatically turn ON/OFF when the vehicle is ON/OFF, different channels can set by the button on monitor, NOTE: CH2 is as reversing channel, can be triggered by the Green wire (Connection Diagram and Installation Instruction are included)
▶7 inch Rear View Monitor and 2 Channel Video Inputs – 7 Inch LCD display monitor can directly attached to dashboard or windshield with provided brackets, and the monitor also has capability to monitor two video inputs CH1/CH2. CH2 connects reverse camera, and CH1 can add a front/side camera for better safety. Additional backup camera recommended: VECLESUS VC4( ASIN: B08C547FSW ) or VC5( ASIN: B09G5TCDBZ )
▶Wide Voltage 9-36V for Widely Used – Support Voltage Range From DC 9-36V DC Power, perfect for wide variety of all large Vehicles, especially suit for Trucks/ Recreational Vehicles/ Trailers/ Bus/ Harvester/ Pickup/ Motor Home/ Van and etc. No worry about the length of the cable, it is equipped with 66ft(20M) cable to meet all your needs
▶IP69K Waterproof and Super Ircut Night Vision – Based on IP69K Waterproof Level and CMOS Sensor will present superior clear images even on rainy days. While the IR LEDs will give low light compensation and ensure the vivid images during the night
▶Reliable service& Warranty – Our car backup camera system has 2 years Warranty and 24 hours tech support and replacement service. Any problems, please feel free to contact us via amazon or the method to contact us had highlighted on the user instruction
