Price: $99.99
(as of Aug 15, 2024 21:15:23 UTC – Details)
2 Channel Video Inputs
The monitor with two way video inputs AV1/AV2–the default set AV2 for current system, AV1 input is optional to wire a additional front/side/rear view camera.
You can wire it for only rear view by powered with reverse lights for camera or full time constantly view by powered with running lights /car battery for camera.
Image Flip
You can roate the image on the screen by “MENU”button to get your need:Mirror/Mir-flip/Normal/Flip.
Wired backup camera system
It keeps great signal no matter where you are.This wired backup camera and monitor kit never has picture delay or signal issues, different from the unstable wireless products.
170° Wide View Angle
Upgraded rear view camera with a 170° wide viewing angle and 6 layered all glass lens makes you always have an eye on your surroundings and the full vehicle width.
18 IR Night vision & IP 68 Waterproof
The 18 IR lights brightness will atuomatically turn on/off according to enviorment.Make sure driving safety at night or bad days.
IP68 Standard Waterproof level allows it to work fine in most conditions.
Easy to install
The package includes all need parts, offering detail installation instruction.
7″ TFT LCD Monitor Specification & Rear view Camera Specification
Screen Size 7 inch Resolution 800*480 Display Component Color TFT LCD Operate mode key operation & remote control Power 12V-24V TV System PAL/NTSC auto Effective Pixels 752*582 pixels Lens Viewing Angle 170 Degrees(Pin Lens: f=2.1mm / F=2.0) Image Sensor CCD Operating voltage 12V-24V Waterproof IP Rate IP68 Work Temp -20℃~+60℃
Product Dimensions : 10.06 x 7.5 x 5.07 inches; 4.49 Pounds
Item model number : JNN-07
Batteries : 1 Unknown batteries required. (included)
Date First Available : August 20, 2018
Manufacturer : YEDDY
ASIN : B07GNY8WDG
Country of Origin : China
【Upgraded 170° wide viewing angle camera】Upgraded backup camera with a 170° wide viewing angle and 6 layered all glass lens makes you always have an eye on your surroundings and the full vehicle width.
【7″ HD Digital Color Monitor】7″ monitor with super large HD(800*480) screen.This provides a super sharp image from the backup camera view.The monitor support 2 video inputs.Monitor automatically turns on and switch to AV2 rear view picture when reversing .
【Designed For Lots of Vehicles】There are 2 different mounts for the monitor for optional,you can put the monitor hanging overhead or standing on dashboard .Our backup camera system includes 20 meters 4 pins aviation extension cable ,which is more suitable for Truck/rv/Bus/Vans/5th wheel/Camper/Hitch hotel,etc.
【IP68 &18 Infrared Lights】 International Standard IP68 waterproof level, make sure the camera can work well in all weather conditions.18 Infrared lights provide excellent night vision performance,this night vision will be even without any ambient light at all.
【Customer Service】All product will be offered a 30 days’ refund.12 months brand new replacement post within 24 hours If any defective item when receive .We provide 24 Hours Customer Service and Technical Support.
