Price: $129.99
(as of Sep 23, 2024 10:15:12 UTC – Details)
Digital Wireless Backup Camera with 7 Inch DVR IPS Monitor Real Time Rear View Observation System
Why choose Lianxinxu wireless reversing system:
1.Stable and reliable digital wireless reversing camera signal allows you to see a stable picture.
2. Provide you with clear and sharp 1080P high-definition images to ensure 100% safety when driving during the day and night.
3. The wireless reversing camera adopts the latest sealing technology, IP69 waterproof, so you don’t have to worry about the problem of water entering the camera.
4. Easy to install, because of the wireless display and wireless camera, the installation is easier.
5. Technical service, The product comes with detailed instructions, so you can use it with confidence. If you encounter problems, you can contact the seller and we will provide you with services.
Wireless Backup Cameras for Pickup Truck Trailer Bus Camper Boat
Easy to Install
No need to run wire between monitor and backup camera, just connect the camera to taillight/power,Then plug in the cigarette lighter socket to power the monitor and you can use it.
Guide lines ON/OFF
You can turn on/off the guide line on the screen to reduce unnecessary dangers for your driving and reversing.
IP69 Weatherproof
The upgraded camera has excellent IP69 water resistance, can be installed outside the car even in bad weather, and performs well in extreme temperatures from -4℉~158℉.
Recording Functions
Monitor and record your driving to make driving safer. It will record what is shown on the monitor. SD card holds evidence to protect your rights. (Note: SD card is not included in the package)
170° wide angle
The digital wireless reversing camera with wide-angle lens provides you with a 170-degree wide-angle field of view, reducing blind spots for you. Make your driving safer and easier.
Two installation methods
The installation is relatively easy, the display can be installed on the dashboard or the windshield, you can choose the installation method of the display according to your needs.
【HD Display】Enhance your driving experience with the digital wireless backup camera system. The system features a large 7-inch LCD monitor and stunning 1080p video capture resolution for crystal-clear images, allowing you to see everything with unparalleled clarity and detail.
【Clear Recording】Our wireless digital rear view camera is equipped with advanced color night vision technology, only needs 0.5 lux lux level to see in the darkest environment. Whether it’s backing up in a dimly lit parking lot or driving through a dark alley, it helps us document every situation we experience.
【Easy installation, hassle-free use】With multiple installation options, including dashboard mount and surface mount, you can easily install our system in any vehicle. Plus, with a wireless connector type, you won’t have to deal with messy cables or wiring.
【Third eye Angle of view】With a real angle of view of 145 degrees, our rear-view camera gives you a view of your surroundings. Whether you’re backing up, changing lanes, or merging onto a highway, you’ll have a clear and comprehensive view of everything around you.
【Wise man’s choice】Don’t settle for less when it comes to your safety on the road. A car costs hundreds of thousands of dollars, but a backup camera only costs a few dollars. Selling at cost price, collect and compare first, and then place an order. If you buy expensive, I will compensate you.
