Price: $119.99 - $135.99
(as of Aug 25, 2024 11:30:31 UTC – Details)
Car Rear/ Front Camera
*Front Camera for normal viewing and NO GUIDE LINE
*Rear Camera for mirror viewing and No Guide Line
*Auto IR Cut Night Vision: Built-in 18 IR LED lights, good performance in day and night.
*Automatically switches to IR when light level is low. Night visible range to 30 ft.
*IP68 Waterproof, High strength weatherproof lens
Image Sensor: CMOS 7030 HD Senso
TV System: NTSC/PAL
Resolution 420 TV lines
Video Output: RCA connector,1.0vp-p 75OHM
S/N Ratio: Better than 48db
Power Supply DC 9V -DC 24V
Work Temperature: – 20°C ~ 60°C
White Balance: Auto Tracing
Car Side View Camera:
Normal viewing and NO GUIDE LINE
Chip: Color 1/4 Sharp CMOS
Format: PAL / NTSC
Resolution: PAL: 500 (H) x582 (V) / NTSC: 510 (H) x492 (V)
Horizontal: 420TV Lines
Night vision distance: 10M
SNR: more than 48dB (AGC OFF)
7″ Color TFT LCD Monitor:
Power Supply: DC 9-36V
Resolution: 800 x 480 RGB
*Image can be switched left and right, up and down.
*You can see 4 direction scenery on a display outside the car.
*4 Channels input: V1/V2/V3/V4
Housing Material: ABS
Display Mode: 16 : 9
Video Frequency: PAL / NTSC
Operation Temperature: -20 ~ 60 degrees
Language:Japanese/Russian/German/French/Spanish/Portuguese/Italian/Chinese/English
Package Contains:
1 x Quad Split Monitor
2 x Side View Camera
2 x Rear View Camera
4 x Video cable
5 x Power Cable
1 x Suction Cup Mount
1 x Dashboard Stand
1 x IR Remote Control ( Battery not included)
1 x Installation Instructions
HD 7 INCHS MONITOR WITH 4 CHANNEL SYSTEM: High resolution, clear image; 4 Channel input; 4 split video displays–4 in 1, 3 in 1, 2 in 1 or full view. The Image can be rotated horizontally and vertically for mirror or normal viewing Via the remote control
4PCS NIGHT VISION CAMERAS: 2pcs Rear View Cameras with 18 Infrared Lights and 7030 HD CMOS Sensor + 2pcs Side View cameras. The cameras are IP67 Waterproof for full potential on any season, 170 degree wide angle let you have a broader perspective
EASY INSTALLATION: Just plug in the car charger, then the monitor will be turn on. At the same time, the monitor has a extensions cables for cameras, making the installation more convenient
WIDE APPLICATION: 12-24V DC Power Supply, Suitable for Trucks, RVs,Trailers,Bus,Vans. And there come with Suction Cup Mount and Dashboard Stand, meet your various installation needs
