Backup Camera Hard Wired Backup Camera 9” Quad Split Screen HD Rear Backup Camera Monitor System, Waterproof IR Night Vision Backup Camera for Trucks,Trailer Heavy,Box,RV,Camper Bus Rearview Camera
Price: $179.99 - $145.99
(as of Aug 30, 2024 01:30:30 UTC – Details)
BACKUP CAMERA KITBACKUP CAMERA KIT
Hodozzy 9 Inch Quad Split Screen Wired Backup Camera And Monitor System, + 2 Rear View Cameras + 2 Front View Cameras
Monitor Specifics:
Power Supply: DC 9V-35VDisplay Rate: 4:3 / 16:9 selectTV system: PAL (CCIR), NTSC (EIA) PAL: 625 Lines; NTSC: 525 LinesEffective Pixels: 800(RGB)×480 pixelsBrightness:300cd/㎡Power Consumption:5WOperate mode: Key operation & remote control4 Video signal input (quad image,2/3/4 images optional)Automatically Switch: The monitor will automatically switch to rear view camera image when reversingUltra-low power consumption, to prevent over heat and easy to install.Operating temperature: -15℃ – +50℃Storage temperature: -20℃ – +70℃Language:Chinese,English,Japanese,Germany,French,Russian,Spanish,Portuguese,Italiano,Russian,Turkish,Polish
9 Inch Backup Camera System Kit with 4 Cameras9 Inch Backup Camera System Kit with 4 Cameras
Wired Backup Camera and Monitor System + 2*10 meters Cable + 2*20 meters Cable
The monitor has six color cables (Red / black / blue / white / green / brown ).
The red wire connected to positive 12V/24V, black wire to ground. If you use one camera as a backup camera, Connect the corresponding color cable to 12V/24V positive power accordingly (Blue-CH1, White- CH2 , Green- CH3, Brown -CH4)
eg: If the blue wire is connected to backup light positive, when you pluu reverse gear, the monitor will automatically show the backup image( CH1). When the reversing finished, the monitor will return to original video showing mode. Kindly note: The 4 colors cables ( blue / white / green / brown ) could not connected meanwhile, you only need to connect one of them if you choose one camera as a reversing camera.
The 9 inch monitor is quad split screen.It could show any channel alone, also can show several channel meanwhile. The package include 4 cameras and 4 extension cable (2*10m, 2*20m). The install is very easy, please reference the above wiring diagram. The connector is pins type, please be careful connect it correct and tightly. Every connector has interface mark.
cameracamera
2 Front View Camera + 2 Backup Camera
Camera Specifics:
Vision Degree: 150°Waterproof grade: IP68Operating voltage: 9V-35VSignal format: PAL /NTCSResolution: 800TV lines, Chipset: 1/4 inch CMOS7440HVertical Sync Frequency: 50/60Hz, Minimum illumination: 0.01luk/f1.2Power Cord: 4 pins type, strong anti-interference, waterproof connector, more closely connectedPlease Note: 2 cameras (without guide lines) + 2 backup cameras (with guide lines)Cameras are 360-degree adjustable, for more flexible installation.If any connection issue, please message us.
9 IN BACKUP CAMERA SYSTEM AND MONITOR9 IN BACKUP CAMERA SYSTEM AND MONITOR
4 Split Screen Modes Choose:
Monitor allow to set display 1/2/3/4 channels at same timeCH1-CH4 display image from V1-V4 connector accordinglyAutomatically Switch: After proper wiring, the monitor will automatically switch to single channel of rear view camera image when the reverse gear is pulled (Operated by remote) Image can be rotated horizontally and vertically for mirror or normal viewingMore setting on remote control “Menu”: select settings of Brightness, rotate image, contrast, language etc.Warmly tips: if you want to adjust something, please choose the Channels you need to adjust.
Rear Assist guildline Lines:
2 front view camera (without guide lines)2 backup camera(with guide lines)CH4 channel can adjust turn on/off guide line, you can choose one camera as backup camera on CH4.
Image Flip:
The default is mirror image for rear view.With image flip function you can switch to facing view (front view), or images upside down (Vertical flip).Warmly tips: if you want to adjust image, please first choose the camera channels you need to adjust. then set.
Package Content:
1* 9 Inch Monitor1* Power Cord1* Dashboard Mounting Bracket4* Aviation Type Cameras2* 33ft Length Cables2* 65ft Length Cables1* Remote Control
4.2 out of 5 stars
85
3.9 out of 5 stars
317
38
38
4.2 out of 5 stars
85
38
$69.99$69.99 $149.99$149.99 $129.99$129.99 $49.99$49.99 $99.99$99.99 $59.99$59.99
Signal
Wired Wired Wireless Wireless Wired Wireless
Camera Quantity
2 4 2 1 2 1
Split Screen
No Split Screen Split Screen Split Screen Split Screen No
Screen Size
7 inch 7 inch 7 inch 7 inch 9 inch 5 inch
Video Record
NO NO YES YES YES No
9 Inch Split Car Rear view Monitor: 4-channel video signal input (quad image, 2/3/4 images optional), each screen can be individually. Image can be rotated horizontally and vertically for mirror or normal viewing, meet your demand.
Car Backup Camera Kit: 9″ Color TFT LCD monitor + 2 rear view cameras & 2 front view cameras + 4 pin waterproof connectors cable, strong anti-interference, provides a more stable signal and clear image.
Front & Rear View Camera: The rearview backup camera kit with 2 front view camera (without guide lines) + 2 backup camera(without guide lines), 140 degree wide angle catches more blind angle, IP 68 waterproof and 18 IR lights night vision provides you a clear image.
Easy to Install: 4-channel split car rear view monitor only need monitor connected to power, then the power could transfer from 4-pins aviation connectors extension cable to camera, needn’t to connect more cable, solve wiring inconvenience.
Reliable & Friendly Customer Service: 30 days money back service, 12 months replacement, life time technical support. If you have confusion, please contact us anytime.
