Price: $199.99
(as of Aug 11, 2024 04:00:16 UTC – Details)
Red Dot Award: Product Design 2020
Safe to use in the home, outdoors, and at the cottageSupports up to 300 W devices (500 W surge)Stores 470 Wh (130,500 mAh) of lithium-ion energySimultaneously charge and operate multiple devices*Heavy-duty aluminum polycarbonate shell for on-the-go durabilityLarge LCD screen with usage and power indicatorsHigh-speed USB-C Power Delivery and Qualcomm Quick Charge TechnologySolar panel** charging port allows for off-grid power capability
*Exception: USB-C does not support pass-through charging during re-charge of the power station via the wall changer
**Optional solar panel not included
Input & Output Ports
Input: DC Charging Port (5521) 5-26 V, 3A; normally used to recharge via AC adapter (included) Input: DC Port (6530) 13-20 V, 6A; normally used to charge optional solar panel Input: USB-C PD port One (1) USB-C port, 60 W supports (5V/3A; 9V/3A; 12V/3A; 15V/3A, 20V/3A) Output: USB Ports (4) One (1) USB-C PD port, 60 W (5V/3A; 9V/3A; 12V/3A; 15V/3A, 20V/3A); One (1) USB-A port with Quick Charge 3.0 Technology (5V/3A; 9V/2A); Two (2) USB-A ports (Total 5 V, 3.1A) Output: DC Port (6530) 9-12.6 V, 6A Output: Car Port 12 V car port (output): 12 V, up to 8A (120 W max) regulated Output: 110 V AC Inverter Two (2) 110VAC, 60Hz, 1@ 3-pin, 1@ 2-pin; Supports 300 W Continuous, 500 W Peak Surge; Pure Sine Wave
Specifications
Cell Chemistry Lithium-Ion Storage Capacity 470 Wh (10.8 V, 43.5 Ah), peak capacity Cell Pack Capacity 130,500 mAh @ 3.6 V Cell Lifecycles ≥ 500 cycles to 80% with full charge/discharge Cell Shelf Life Up to 6 months after full charge; recharge once every 3-6 months Wattage Compatibility 300 W Continuous, 500 W Peak Surge Battery Management System Over Voltage Protection, Low-voltage Protection, Over Temperature Protection, Short Circuit Protection, Over Current Protection Display Panel 4.7″ LCD screen clearly displays watt input/output, battery status Cabinet Durable Aluminum Polycarbonate shell Colour Light grey and black Weight 5.32 kg (11.72 lb) Dimensions (LxWxH) – 28 x 16 x 21 cm (11.0 x 6.3 x 8.1 in) Operating Usage Temperature 32°-104° F (0°-40° C)
4.2 out of 5 stars
55
Inputs
(1) DC Charging Port (5521); (1) DC Port (6530); (1) DC Port (6530) 1) DC Charging Port; (1) Anderson port (PA45)
Outputs
(4) USB Ports; (1) DC Port; (1) Car Port; (1) 110 V AC Inverter (4) USB Ports; (2) DC Ports (DC5525); (1) 12 V Auto Port; (2) 110 V AC Inverter
Energy Storage Capacity
470 Wh (10.8 V, 43.5 Ah), peak capacity 786 Wh (10.8 V, 72.8 Ah), peak capacity
Cell Pack Capacity
130,500 mAh @ 3.6 V 218, 400 mAh @ 3.6 V
300 W Continuous, 500 W Peak Surge 500 W Continuous, 2500 W Peak Surge
Display Pane
4.7″ LCD screen LCD Screen
Cabinet Material
Aluminum Polycarbonate ABS Polycarbonate
Weight
5.32 kg (11.72 lb) 7.8 kg (17.2 lb)
Dimensions
28 x 16 x 21 cm (11.0 x 6.3 x 8.1 in) 35 × 16 × 29 cm (13.7 × 6.3 × 11.2 in)
