Price: $23.29
(as of Aug 20, 2024 19:45:17 UTC – Details)
4.2 out of 5 stars
19
4.2 out of 5 stars
19
$21.89$21.89 $18.84$18.84
Perfect for
Indoor use, travel, lighting candles, lighting appliances Outdoor grilling, camp fires, hard to reach locations
Charge Time
40 minutes via micro USB 40 minutes via micro USB
Safety Features
Slide while pressing unlock button to turn on Slide to reveal on button , then press to ignite
UPGRADE FROM MATCHES : The USB Rechargeable Lighter is a modern take on the limited cool lighters you are used to. The slim designed electronic lighter create an electric arc ignition with sparks that mimic the heat combustion needed for a flame. These long lighter design makes them perfect as lighters for candle and with the use of kindling perfect to as a camping lighter
SAFELY DESIGNED: Flameless lighters are built to be safer lighters . The extra reach stick lighter has a child safety switch that has to be slid upward to be turned on. The electric arc light is narrow enough so that no full finger can fit in between. The rechargeable battery circuit is built to prevent overheating and overloading.
A CAMPING LIGHTER AND MORE : A traditional lighter is effective but not as efficient as an electric lighter. Electric lighters are long lighters perfect for the deep reach needed for use as a candle lighters or as a grill lighter. Their unique ignition makes them windproof lighters able to withstand the perils of camping and their butane free status makes them safer around a camping stove.
SMART TECH ACCESSORIES: The traditional arc lighter has 100 ignitions per charge. The Avalanche USB rechargeable lighter has 300 ignitions per charge, has a micro-USB and an LED display that indicates when a USB lighter rechargeable status is complete.
SPECS: Zinc and Aluminum body material; 40 minute charge time via Micro-USB (Included) Dimensions: 260mm x 17mm x 17mm
