ASA Jensen JTV1917DVDC 19″ 720p Inch LCD TV with Built-In DVD Player, DC Power , Black
Price: $268.83 - $247.63
(as of Aug 12, 2024 03:30:23 UTC – Details)
JENSEN JTV1917DVDC 19″ LED TV with Build-In DVD Player, High Performance Wide 16:9 LCD Panel, Resolution 1366 x 768, Integrated HDTV (ATSC) Tuner, HDTV Ready (1080p, 720p, 480p), 12V DC Power – Replaces the discontinued JE1914DVDC
The compact TV/DVD design of the JTV1917DVDC saves spaces in an RV by eliminating the need for additional electronics. By functioning on a 12V DC power system, JTV1917DVDC draws a low power consumption making it perfect for dry camping. In the off season, the included 110V AC/DC power adapter allows RVers to move their TV from the RV in to their home.
Key Features
  • 12V DC Power
  • Built-in DVD player
  • High performance wide 16:9 LCD panel
  • 1366 x 768 resolution
  • 16.7 million colors
  • Integrated HDTV (ASTC) tuner
  • HD ready (1080p, 720p, 480p)
  • VESA 75mm x 75mm mounting pattern
  • Full function wireless remote control included
  • 12VDC cigarette adapter cable included
  • 110VAC AC/DC power adapter included
Specifications
  • Diagonal Screen Size (Inches): 18.5
  • Video / Display System: NTSC/ATSC/PAL
  • Aspect Ratio: 16:9
  • Resolution: 1366 x 768
  • Brightness (cd/m2): 200 nit
  • Contrast Ratio: 1000:1
  • View Angles: Top 89°, Bottom 89°, Left 89°, Right 89°
  • Speaker Audio Output: 3Wx2
  • Power System: 12VDC
  • HDTV Ready: Yes
  • Composite Video Input: 1x NTSC/PAL Compatible
  • Component Video Input: 1x Y, Pb, Pr
  • VGA Video Input: 1x
  • VGA audio input (3.5mm stereo mini phono) x 1
  • HDMI (ARC) input x 1
  • Selectable (variable/fixed) analog audio output (RCA) x 1
  • Digital SPDIF audio output (RCA) x 1
  • Headphone output x 1
  • Overall Dimensions: 17.44″W x 10.97″H x 1.84″D
  • Weight (Lbs): 7.0
JENSEN…the ONLY brand of TVs designed, engineered, tested & built exclusively for over-the-road applications
12V DC Power, High performance wide 16:9 LCD panel, 1366 x 768 resolution, 16.7 million colors, Integrated HDTV (ASTC) tuner
HD ready (1080p, 720p, 480p), VESA 75mm x 75mm mounting pattern
12VDC cigarette adapter cable included, 110VAC AC/DC power adapter included
