Price: $25.99
(as of Aug 25, 2024 17:45:59 UTC – Details)
Artilife compact electric stove is perfect for Moka pot/Turkish coffee pot/Cuban coffee pot,perfect for the coffee maker.
for coffee-loving
Perfect for moca pot
【USE MATTERS】1.Smell of plastic when you first use it,the very first time you turn it on,do it outside with a pot of water,and run at MAX heat level 5 for 15 mins outdoors to get rid of the smell. Plus if you let it run without water,the stainless steel part will be brown easily. 2 The burner transfers heat to the pot by heating itself,do not touch the stove body during use.3. When the electric stove is not in use,be sure to turn the switch to the “off” position and unplug the plug.
【Adjustable Temperature】Small hot plate level 1 to level5,and level 5 is MAX.Temperature can be controlled by dial well.
【Cycles On and Off 】Mini hot plate runs in On and Off Cycles,Cycles‘on and‘off’to maintain plate temperature.If you set level 1,it keep cutting off before the water started to boil, So if you want your water to boil quick,you need set at least level 4.
【Saves Space】Artilife mini electric stove is compact,takes up very little counter space,small enough to pack,suitable for home,hotel,office,camping,and your RV.
【Electric Camping Stove】Artilife 500W small electric hot plate is great for camping with a portable power station.
【Heats Up Fast】500w small electric hot plate preheat before use.It takes a minute or two to reach full temperature,once it has reached full temperature,it Heats-up quick.
【Solid Burner】Cast iron heating plate,Stainless steel collar,Insulated wire,Equipped with non slip rubber feet to be more stable,Solid burner surface makes it easy to clean and retains heat.
【Small Hot Plate 】4″ in diameter the heating element,definitely for small pots & pans.It can heat up your stainless steel moka pot,coffee kettles,tea pot,glass cup,ceramic mug and non stick mini pan,pls notice the base must be under 5″ in diameter.
【500w,110v AC Power】Low Power Consumption,be good to use in an RV.
【Package Included】1 x Mini portable stove; 1 x Instruction manual.
