Price: $1,568.00
(as of Jul 26, 2024 23:30:18 UTC – Details)
Portable ARB10802692 ZERO Fridge/Freezer Electric Powered 12/24V DC – 100/240V AC
ZERO Series – Dual Zone Range
Capacity: 73 QT (108 cans x 375 ml) / Wireless Monitoring and Control/ Ideal for: Trucks, SUVs, Campers, RV, Boat and even Home
ZERO SERIES Dual Zone ARB 10802692 – 73 QT
Suitable for many medium to large SUVs, wagons and trucks, the class-leading 73qt ARB ZERO Fridge Freezer has two compartments – 25.4qt and 47.6qt making it your perfect traveling companion. This model also features a removable compartment divider allowing you to convert your dual-zone fridge/freezer into a single zone.
INTRODUCING DUAL ZERO SERIES
Keep the cans cold and your meals frozen, look no further than ARB’s new ZERO Fridge Freezer Having both Fridge and Freezer space at one time means you can travel for longer periods
WIRELESS – Monitoring and Control
Monitor your ARB ZERO portable fridge freezer wirelessly via your Bluetooth-enabled mobile device by downloading the free app in the app store. The Zero Connect app allows the user to monitor status
Transit Bag – Part N°10900053 for 73QT Dual Zone
Transit bag shields your fridge from dents and scratches while also providing additional insulation in extreme temperatures. Made of tough, durable material, it features dual side storage zip pockets
POWER PACK – ARB ZERO Fridge Part N°10900050
Keeping your portable fridge powered so your food remains cold without the need to be hooked to your vehicle, the lightweight Power Pack features a 15Ah lithium battery for up to 18 hours of runtime
ARB ZERO FRIDGE SLIDE – Part N° 10900048 for 73QT
The Fridge Slide is a mounting solution for your Fridge due to its compact design which minimizes cargo intrusion. With a flat base for secure fitment, the slide ensures easy access to your fridge
BUY IT WITH
– Fridge Slide: Part N° 10900048
– Transit Bag: Part N° 10900053
– ZERO Fridge Tie Down Kit: Part N° 10900046
– ZERO Portable Power Pack: Part N° 10900050
EXTERIOR AND CASE COMPONENTS
Tough, durable steel outer casing / Quick-release side opening reversible lid / Non-slip glass bottle provision / Recessed carry handles / Full-height corner mouldings / Boost function for rapid cool down / Easy view LED display / Front AC power inlet / Dual DC power inlet at opposite ends
INTERIOR COMPONENTS
The 73qt model offers dual compartments separated by an internal lid / Dual independently controlled cooling zones. Features a removable compartment divider (white), remove to create a single zone fridge or freezer and pick up 4qt of space / Drain plug for simple cleaning / LED interior light
Capacity 73QT (87 x 375ml cans with compartment and 108 cans without) External Dimensions (L) 29.7 in x (W) 18.5 in (H) 22.2 in Internal Dimensions Upper Compartment: (L) 15 in x (W) 12.8 in x (H) 10.4 Lower Compartment: (L) 8 in x (W) 12.8 in x (H) 7.1 in Rear Zone: (L) 6.7 in x (W) 12.8 in x (H) 17.5 in Weight 72.8 lb Cooling Capacity -7.6°F to +50°F Power Voltage: 12/24V DC / 100 240V AC Integrated battery protection system Current Draw 2.9Ah (DC12V set at 5 C, 32 C ambient temperature) Transmitting module Bluetooth connectivity allows 2-way communication on your mobile device
Leading Manufacturer Of High-Quality Products
International Renown For Our Diverse Range Of Award-Winning Products
Designed With The User In Mind
Proven And Tested For Durability And Function In Real-World Conditions
Meeting Or Exceeding All Required And Standardized Testing
