Anrapley Lighter, 6.0in Long Butane Torch Lighter with Fuel Level Window, Windproof Pen Lighter Adjustable Jet Flame for Candle Fireplace Grill Kitchen BBQ, Dad Gifts, Black(Gas not Included)
Price: $9.98
(as of Aug 25, 2024 20:45:22 UTC – Details)
This lightweight torch lighter easy to carry, 6.0 in long body holds comfortably. It is very suitable for BBQ, candles, camping, fireplaces, stoves, etc. a ​great gadgets gifts idea for Friend, Father’s Day, Birthday, Thanksgiving, Christmas etc.
NOTE: Only takes 4s to fill the lighter tank with butane fuel, overfilling will cause butane leakage, Please pay attention to the butane level by fuel visible window when filling.
Stable Placement
The butane lighter is designed to have a diameter of 0.7in, which can be stably erected on the desktop.
Men Gifts Idea
The lighter is stored in a beautiful gift box, a great gifts idea for Friend, Father’s Day, Birthday, Thanksgiving, Christmas etc.
Strong Blue Flame
This torch lighters powerful torch jet flames can easily against any breeze, strong blue flame.
Cooling Hole Design
The cooling holes design allows the ignition port to cool down more quickly.
Fuel Visible Window
The lighter has a fuel visible window, you can check the gas balance and fill it at any time.
Adjust Flame Level
You kan adjust the flame level by twisting the adjustment valve at the bottom of the lighter.
— Warnings:
1. Keep lighter out of reach of children !!
2. Keep flame away from face, skin and clothing during use !!
3. Be sure that the very hot flame is OUT completely after use !!
4. Store lighter properly….away from direct sunlight !!
5. Do not touch the flame outlet until it has a chance to cool down !!
— Butane Filling Tips:
1. Be sure that no visible flame or kindling when filling and keep unimpeded air around.
2. Hold the lighter with the FILL VALVE up, Invert gas canister and insert the gas canister tip into the FILL VALVE, Push the gas canister and lighter together to allow gas to flow into the lighter gas tank. Push it 3-5 times and each time shall last for 5-8 seconds.
3. After supplementing butane, wait for least 2 minutes before igniting.
4. Please allow enough time to cool the lighter to room temperature before filling the lighter with fuel.
▶【UPGTADED DESIGN】- Unlike other cheap plastic lighters, this butane lighter is made of aluminum alloy and adopted surface plating technique, beautiful and durable. To make the push-up switch easier, our non-slip switch adopts the creative idea of 3 layers of steps and 18 raised dots. Segmented design prevents heat transfer, making it safer to use.
▶【JET FLAME & COOLING FASTER】- The torch lighter uses a sturdy turbocharged nozzle to produce a flame of 2850°F up to 3.0in, which can easily resist outdoor wind. High temperature resistant ceramics on the port to ensure long-term use and resistance to deformation, 2 side cooling holes improve the cooling efficiency by 30%.
▶【REFILLABLE & ADJUSTABLE FLAME】- Flame adjustment valve is located at the bottom of the lighter. It may be turned by hand after lifting the recessed semi-circular handle. It’s very convenient to adjust the flame level from weak flame to strong flame. Unlike disposable lighters, it can be refilled and used repeatedly.
▶【FUEL VISIBLE WINDOW】- Don’t worry about when to refuel gas to the lighter, 0.17 ounces capacity can ensure normal use for a period of time, tilt the lighter back and forth to see the remaining butane, which you can check and fill at any time. NOTE: According to safety regulations, The lighter is sold without gas.
▶【MULTIPURPOSE LIGHTER】- According to the ergonomic structure, 6.0-inch long body is more comfortable to hold, safe and convenient to use. It is very suitable for grill, candles, camping, fireplaces, etc. All product sold by us can enjoy 12 month replacement warranty and 30-day money back ensure, if you have any issue about our item, please contact us.
