Anker 521 Portable Power Station Upgraded with LiFePO4 Battery, 256Wh 6-Port PowerHouse, 300W (Peak 600W) Solar Generator (Solar Panel Optional), 2 AC Outlets, 60W USB-C PD Output, Outdoor Generator
Price: $219.99 - $199.99
(as of Aug 08, 2024 12:15:19 UTC – Details)
anker solix c800anker solix c800
Full Power To Light Your Way
One Unit Powers All
anker solixanker solix
Anker is once again proud to pioneer the next generation of reliable, portable power solutions, standing upon our legacy of developing innovative technology. Whether you are looking to take your outdoor adventures to the next level, or protect your home with back-up power, Anker has built a solution you can count on – for whatever you need to power, wherever power is needed.
Choose Your SOLIX F3800
Choose Your SOLIX C1000
Choose Your Backup Power Kit
Choose Your Power Station
AnkerAnker
11
10 Years of Long-Lasting Power: Anker 521 Portable Power Station is built to last over a decade, even with everyday use with our InfiniPower technology. InfiniPower combines LiFePO4 batteries with ultra-durable electronics, a control system that monitors temperature up to 100 times per second, and an impact-resistant build.
USB-C Port Built In: Ditch bulky adapters and use a single cable for fast charging your laptop with the built-in USB-C port. It’s compatible with a wide range of other devices, too.
600W of Upgraded Power: Anker 521 Portable Power Station uses SurgePower to run high-wattage appliances up to 600W.
256Wh Capacity for Weekend Trips: When you’re getting away for the weekend, bring Anker 521 Portable Power Station to charge your devices and small appliances, up to 256Wh.
6 Ports for More Charging: Plug in 6 devices or appliances for your weekend getaway. The power station comes with 2 AC ports, 2 USB-A ports, a USB-C port, and a car outlet.
What You Get: Anker 521 Portable Power Station (PowerHouse 256Wh), DC adapter, car charging cable, welcome guide, our worry-free 5-year warranty, and friendly customer service.
