Price: $749.99
(as of Sep 29, 2024 09:45:20 UTC – Details)
ANCHEER 27.5 inch ebike
🚲【HYDRAULIC OIL DISC BRAKE】Compared to the traditional Cable Brake, Hydraulic disc brakes offer unrivaled precision and stopping power and have fewer components that wear out, resulting in fewer adjustments and replacements. At the same time, Hydraulic disc brakes boast superior heat dissipation capabilities, ensure consistent and reliable braking, allowing riders to confidently tackle steep descents without worries.
🚲【499WH LARGER CAPACITY FAST CHARGE BATTERY】–Up to 25-60 miles per charge with the powerful 48V 10.4Ah battery. Plenty for a day’s adventure or most trips to work and back. The battery adopts the new fast charging technology and only costs you 3.5 hrs for a fully charge. It saves half of the charge time. You can charge on/off the ebike by your convenience. No worry for being stolen.
🚲【48V 500W(750W PEAK) POWERFULL MOTOR】–Equipped with 500W/750W peak high speed brushless motor, increases stronger hill-climbing power, provids more than enough to power your daily commute, a cruise on the mountain, or a meander along your favorite trail. With speeds up to legal safe speed 20 mph, it will get you there swiftly.
🚲【DUAL SUSPENSION】The ANCHEER Upgrade adult electric bicycle comes with an adjustable front fork alloy hydraulic lockout suspension fork and rear suspension, ensuring a comfortable riding experience. Whether you’re landing from stairs, crossing rocky roads, or climbing gravel slopes, the bike provides stable rides. Puncture-resistant, durable 27.5″×2.1″ Mountain bike tires crush over obstacles and shocks, conquering all kinds of rough terrain for a stable ride during your adventure.
【4 Working Modes】-PAS(Pedal Assist) Mode: The motor will assist you with a moderate amount of power as you pedal the bike, kick in 1 of 5 levels pedal assist to meet your needs. Throttle Mode:You can switch LCD Display to 0 level, and then use the throttle to achieve up to 20MPH. Cruise Mode:When twisting and hold the throttle for 8s seconds, the gear signal flashes, it will enter the auto cruise state. Pure pedal Mode:Pedal the bike normally as you would any bike.
【SMART COLOR LCD DISPLAY】-The upgraded COLOR LCD DISPLAY allows you to visualize the speed, mileage,voltage and battery power. In addition, this smart lcd display also provides ERROR Code Indicator functions. Different error codes can accurately locate different product component problems, which is convenient for replacing replacement components.
【EASY TO FINISH ASSEMBLY】–ANCHEER electric bike for adults is 85% pre-assembled and you only need to finish the assembly of main parts. we also have the assembly video for you on the product page. With one-year service for the electric motor, battery and other main replaceable parts, you’ve no worry about using it. There is an electronic user manual at the bottom of this page, you can preview it in advance, and ANCHEER Traveler provides lifetime technical support.
