Aluminum Folding Hand Trucks Portable Luggage Cart Lightweight Travel Hand Truck/Heavy Duty Hand Trucks (100LB)
Price: $21.39
(as of Sep 19, 2024 10:30:37 UTC – Details)
100lb folding handtruck100lb folding handtruck
folding hand truckfolding hand truck CooTool Aluminum Folding Hand Trucks
100LB Capacity Folding Hand Truck Dolly – 2 Wheel Foldable Dolly Cart
MAX WEIGHT 100Lbs & FOLDING DOLLY CART
With a unibody design, the base plate is easy to unfold and loads up to 100 Lbs
folding dolly cartfolding dolly cart Easy to fold and unfold, just need to step on the plate.
Lightweight, folded up width 1.5in, the folding trolley cart very space-saving
CooTool 100LB Capacity Folding Hand Truck Dolly
Unique folding design, two gears adjusting, can fit your needs perfectly
folding hand cartfolding hand cart
folding hand truckfolding hand truck First choice for travel and moving!
Save Your Strength, Happy Lifting!
Weight Capacity
100lb
Weight Capacity
265lb
Weight Capacity
330lb
Material
Aluminum
Material
Aluminum
Material
Aluminum
Cart Weight
3.5 pounds
Cart Weight
9 pounds
Cart Weight
14 pounds
Highest Size
95CM
Highest Size
100CM
Highest Size
120CM
STURDY, LIGHTWEIGHT construction opens and closes in seconds providing easy maneuverability
OVERSIZED rugged wheels for improved handling
ADJUSTABLE SUPPORT strap anchors baggage and prevents shifting
SAFELY TRANSPORTS luggage, boxes and parcels up to a maximum approved transport capacity of 45 kilograms or 100 pounds
FLAT AREA designed to hold load measures 10 5/8 inches at the widest point and 8 3/8 inches long
FOLDABLE for easy transportation and storage
BODY Dimensions: 16.0 x 11.0 x 3.0 inches, Weight: 3.5 pounds
