Alpicool K25 Portable Freezer,12 Volt Car Refrigerator, 26 Quart (25 Liter) Fast Cooling 12V Car Fridge Freezer -4℉~68℉, Car Cooler, 12/24V DC and 100-240V AC for Outdoor, Camping, RV, Truck, Boat
Price: $249.99
(as of Aug 18, 2024 09:15:33 UTC – Details)
11
22
Description
The Alpicool K25 Portable Fridge is a great choice of kit for whose looking for a fridge/freezer portable freezer Whether you’re off to the park for a picnic, or on the road camping for months.It’s invaluable for keeping your food fresh and your drinks cold!.
Ready for hitting the high-way and have a wonderful time on your adventure? Let’s go with the Alpicool K25.
Package
1 X Alpicool K25 fridge freezer
1 X DC power cord(12/24V)
1 X Instruction book
Specification Dimensions:23.03 x 13.19 x 13.78 inches Capacity:26 Quart(25 Liter) Voltage: 12V/24V(DC) Rated power: 45W Temperature Control Range:-4℉~50℉ Noise:≤45dB Net Weight: 27.1 lbs
FreezingFreezing
panelpanel
FoamFoam
2 In 1 Multiple Purpose
Can be a fridge and a freezer at the same time, which meets your different kinds of requirement and lets your every penny play the best value.
Simple LCD Control Panel
Digital control panel. Easily monitor the setting temperature, choose battery protection modes or change between Max and ECO cooling mode.
Reliable Sealing Property Construction
Thick and high Density Foam Insulation effectively lock the temperature without leaking cool air. Keep the item fresh all the way on your trip.
antianti
batterybattery
noisenoise
ANTI-SHAKE
The tough and robust design allows it has a good performance on a dumpy road. Alpicool car fridge can keep running in slopes under 45 degrees. Durable, thick and reliable!
Car Battery Protection
3 stage battery protection setting (H, M, L) to protect your vehicle battery without run down.
Quiet Operation
The car fridge works in Less then 45db, which makes you feel like living in quiet suburb. No need to worry about being disturbed while resting in the car.
1,485
4.2 out of 5 stars
573
4.3 out of 5 stars
984
1,718
4.1 out of 5 stars
1,194
$179.99$179.99
— $289.99$289.99 $299.99$299.99 $379.99$379.99
Capacity
20 cans | 16 quarts | 15 liters 30 cans | 23 quarts | 22 liters 68 cans | 53 quarts | 50 liters 60 cans | 58 quarts | 55 liters 75 cans | 63 quarts | 60 liters
Size Dimension (L*W*H)
22.4″ x 12.6″ x 10.2″ 23.5″ x 12.6″ x 13.2″ 22.6″ x 14.4″ x 19.3″ 27.2″ x 13.6″ x 20.6″ 28.5″ x 14.2″ x 21.6″
Item Weight
21.2 lbs 26.5 lbs 37 lbs 35 lbs 37.5 lbs
Interior Basket
Interior LED Light
Dual Zone Control
Temperature Range
-4℉~50℉ -4℉~50℉ -4℉~50℉ -4℉~50℉ -4℉~50℉
Average Power Consumption
45 Watts 45 Watts 45 Watts 45 Watts 60 Watts
FREEZES WITHOUT ICE: -4°F(-20°C) deep chilling down performance ,can be a frigde and freezer. Run great with your small solar system as well.
STORAGE SPACE: Exterior Size- 23.03″x 13.2″x 13.8″. 26 Quart(25 Liter) capacity.
CAR BATTERY PROTECTION:With temperature memory function and 3 different levels for battery protection: Low, Med and High to protect your vehicle battery without run down.
PREMIUM DESIGN:Hidden handles, New LCD display panel with USB socket to charge your mobile devices.
KEEP COOLING AND FRESH:Reliable sealing property construction,thick and high Density Foam Insulation.Continues keep cooling performance during your journey.
