Price: $1,599.00
(as of Aug 05, 2024 20:45:11 UTC – Details)
1 Home Use 2 Outdoor Camping 3 Outdoor Work
1 UPS Function 2 LiFeP04 Battery 3 APP Remote Control
2000W Max Input
Thanks to AP-POWER technology, you can stack two ways with 2000W max to fill within 1 hour.
1500W Max Input
No bulky adapter is required, AC cable with fast mode can charge it to full within 1.3 hours.
1000W Max Input
The safer XT60 design can reduce the current loss, and 1000W max input makes it full within 2 hours.
Support 12V/24V
Use XT60 input, widely applicable to 12V vehicles and 24V trucks, convenient for your car life.
1 Charge from AC+Solar 2 Charge from AC 3 Charge from Solar 4 Charge from Car
Specification:
Battery capacity 2016Wh (48V-42Ah) LFP Lithium lron Phosphate Rated Power 2500W (Peak 4000W) AC Input (100-120)V~15A Max Solar Input (12~150)V~20A,1000W Max Car Charger Input 12V/24V DC 4* AC / 1* 30A RV AC Output 110V 2500W Max(Surged 4000W) 2* USB-A (Ordinary) Port 5V-2.4A 12W Max 2* USB-A (QC3.0) Port 5V-3A, 9V-2A,12V-1.5A 36W Max 2* USB-C Port 5/9/12/15V-3A, 20v-5A 200W Max 2* DC5525 / Car Port 12V-10A,120W Max Wi-Fi / Bluetooth Support UPS Support Charging Mode Fast Mode (1500W max) / Standard Mode (1000W max)/ Mute Mode (500W max) Size 17.95*14.17*13.62in) Net weight Approximately 64 lbs
【Super fast charging】: ALLPOWERS R2500 has an integrated MPPT charge controller for up to 1000W solar input. At the same time, with the help of proprietary AP-POWER fast charging technology, no bulky power supply adapters are required, only one cable can be used to fully charge the power station within 1.3 hours, the 1500W Max charging power which is also higher than other similar power station. And supports solar and AC charging at the same time to achieve a shorter charging time.
【Power 99% of Electrical Appliances】: With huge rated power of pure sine wave 2500W (Peak 4000W), ALLPOWERS R2500 is ready to power 99% of indoor and outdoor appliances- electric vehicles, TV, coffee maker, air conditioner, toaster, microwave oven, CPAP, drill, Juicer, hair dryer for long time. With 2016Wh battery pack, it features 4* AC outlets, 1* RV outlet, 2* PD 100W USB-C ports, 4* USB-A ports, 2* DC ports, 1* Car socket. 30A RV Outlet is very suitable for long-distance outdoor RV travel.
【Extremely long lifespan LiFePO4 battery】This ALLPOWERS R2500 power station has 2016Wh LiFePO4 battery. The maximum battery capacity is higher than 80% after 3500 cycles of charging and 50% after 6500 cycles. Therefore R2500 lifespan is more than 10 years. Eco mode can shut down R2500 at a fixed time. The R2500 power station features advanced BMS protection that monitors voltage, current and temperature to ensure the safety of the R2500 in all circumstances.
【Smart Control Function & UPS Function】: Easily realized by connecting to ALLPOWERS APP through WIFI/ Bluetooth Power Monitoring/Function Setting/Remote Control/System Upgrade. R2500 is equipped with less than 15ms UPS to ensure the safe operation of CPAP, fish tank, refrigerator or computer when sudden power failure.
【 Package】:1* ALLPOWERS R2500 power station, 1* AC charging cable, 1* user manual.
