ALLPOWERS 606Wh Portable Power Station 700W (Peak 1400W) Solar Generator MPPT Backup Battery with 2 AC Outlets PD 100W USB-C Emergency Power for Outdoor Camping RV Trips Home Off-Grid
Price: $6,298.00 - $269.99
(as of Aug 18, 2024 20:00:18 UTC – Details)
SOLAR POWERSOLAR POWER
solar powersolar power
POWER STATIONPOWER STATION
power stationpower station
SOLAR PANEL INPUTSOLAR PANEL INPUT
FAST CHARGING, DUAL WAY INPUT
Recharging from 0-100% within 3 hours.
Wall Outlet 100W + USB-C 60WSolar Panel 100W + USB-C 60W
Specifications
Battery Capacity 606Wh/164000mAh Rated Power 700W, Peak Power 1400W Output Waveform Pure Sine Wave AC Input AC 110v/60Hz 5.0A Solar Charger 16.6V-24V/5.0A(Max.) from DC/ Anderson USB-C Input 20V3A Car Charger 12V/ 24V 5.0A(Attention: 12V/24V batteries are suitable for charging. 2* AC Output AC 110V/60Hz 700W (Max.) 3* USB-A Output 5V3A(Max.) 1* USB-C Output 5V-20V 5A (PD 100W Max.). 2* DC Output 12V/5A(Max.) 1* Cigarette Outlet 12V 10A(Max.) Size 26.3x14x18cm/10.4×5.5x7inch Weight 5.3kg/11.68lb
🔋【Recharge from 0%-80% within 1.5 Hours】: ALLPOWERS portable power station can discharge from wall outlet and USB-C PD60W simultaneously that takes only 1.5 hours from 0-80%. 4 separated ways to recharge: Indoors, you can get stable 100W input form AC wall outlet (adaptor included) or 60W PD input from USB-C charger. You can also fully recharge it by 12V/24V car outlet or clean solar power(100W max). Keep your portable generator always full whenever you are at home, camping or on road trip.
🔋【Powering Up to 9 Devices Simultaneously】: With a 606 watt-hour large capacity, ALLPOWERS portable power source features 2*AC ports (110V 700W, peak 1400W), 1*USB-C 100W port, 3*USB-A ports, 2*DC ports, 1* Cigarette outlet. Portable power source provides 9 ports, specially designed for charging laptops, juicer, mini-cooler, drone, toaster and other outdoor electronics, power your outdoor adventure to avoid anxiety.
🔋【New APP Experience and LED lights】: Remote controlled by ALLPOWERS APP with Bluetooth , easier to operate the LED lights and AC DC output. LED lights has two modes. High-light mode can be used as lighting for outdoor fishing, camping, car repair and off-grid. So convenient that you needn’t to buy other lamps. SOS mode can help you get help quickly in dangerous situations.
🔋【Protect You Devices】: ALLPOWERS has passed professional UL & FCC certification. Battery Management System ( BMS ) with the protection of over-temperature, over-voltage, over-power, over-current, and short circuits, maximally keep your charged device safe. PURE SINE WAVE output helps electronics less wear, keep sensitive electronics running smoothly while the modified sine wave inverters tends to damage electronics.
🔋【Widely Range of Application】: The backup battery is perfect for (1).Home power outage, backup battery with 2 lights for your computers, phones or other emergency devices, make you relax; (2).Road trips, easily stored in RVs, trailers, enough to power laptop, fan, drone,toaster, and all your electronics devices; (3).Outdoor grill party, powers up a small blender, pellet smoker, small ice shaver, projector for a nice movie and grill party in a starry summer night with friends and families.
🔋【What You Get】:1* ALLPOWERS 606Wh Portable power station, 1* AC adapter and cable , 1* User guide.
