AIVOLT Portable Power Station 300W Mini Solar Power Bank, Backup Lithium Battery with LED Light 120V Pure Sine Wave AC Outlets, for Outdoor Camping Emergency Home CPAP Backup (watts, 0300)
Price: $149.00
(as of Aug 27, 2024 17:15:17 UTC – Details)
AIVOLT Portable Power Station 300WAIVOLT Portable Power Station 300W
Battey capacity-288whMax Power-300 wattRated Power-250 watt
Portable power bank with ac outletsPortable power bank with ac outlets
Durable Portable Power Bank
Aviation Grade Aluminum Cover
2.5mm aviation grade aluminum cover is not only durable but also features excellent heat dissipation, outshining other plastic covers. No need to worry about the weight, it is only 7.7lbs.
Battery Management System(BMS)
This 300 watt portable power station is designed with a built-in Battery Management System, offering strong protection against over voltage, over current and over temperature, to guard user safety.
power staion with pure sine wavepower staion with pure sine wave
Pure Sine Wave Output
​The VP300 portable power bank with ac outlets features pure sine wave output, which is able to power most sensitive electronics like CPAP machines, laptops, tablets, cameras, drones, smart phone switches etc., and would never damage your devices
Pass-through Charging
This solar battery station also can be used as a plug board, as the pass-through charging technology allows it to be used while charging. When your battery station and phones are out of power outdoors simultaneously, you can use solar panels to power this battery station, and get power from the station for your phones
Portable solar batteryPortable solar battery
Portable power station with ac outletsPortable power station with ac outlets
Power Station 300wPower Station 300w
Ergonomical Handle
The mechanically durable handle allows you to move this 7.7lbs solar powered battery easily. You can take it to anywhere you need power on.
LED Flashlight
The 5W LED light can throw a warm light in the dark night of camping, fishing, or power outages. Bright enough to light your work area when sitting up a tent or something like that.
What You Get
Solar Power Bank*1, Power Cable*1, Adapter*1, Car Charger Cable*1, Manual*1,3-prong AC Plug Converter*1
Portble Power bank for camping fishingPortble Power bank for camping fishing
AIVOLT Portable Power Station 300W Large CapacityAIVOLT Portable Power Station 300W Large Capacity
FAQ
Q1. What’s the working times for my device?
A1. Working time(h) = capacity (288Wh)* conversion rate (0.85) / operating wattage of your device
Q2. What solar panel should I use?
A2. This solar power station can be charged by a solar panel with an Anderson plug. Rated Wattage: 60W-100W. Rated Voltage: 19.8V. Rated Current: 3.03A-5.05A.
Q3. Can I use and recharge this mini solar generator simultaneously?
A3. Yes, our battery bank VP300 can be used and recharged at the same time.
AIVOLT Portable Power Station 300W/288
