Price: $35.99 - $22.99
(as of Aug 18, 2024 19:30:14 UTC – Details)
Upgraded Gravity Design
Just slide in, Real one hand operation, Slide Instead of Button Pressing
Click the Video to learn more
As its gravity design, car phone holder mount clamps the phone automatically by gravity and provide the easiest operation and a strong stable hold without button to press when you slided phone into mount.
Upgraded Hook Design – Attach Vent+Hook Vent
100% Never Slip & Fall
This car vent phone holder mount is designed as “Hook shape” and form “Three grasp points” which can firmly hook around the a/c vent for no slippage or movement. It solving the market’s common problem of falling forward and off the air vent constantly when going over bumps or turns.
1 Heat Resistant 2 66LB Load Bearing
👍 3 in 1 ULTIMATE CAR MOUNT: Are you not sure which installation method is better for your car? Aiming to resolve dashboard or air vent compatible issue, low temperatures in winter and heat in summer of environmental influences, this 3 in 1 phone holder for car vent dashboard windshield offer you the most ideal installation method for your car. Dashboard & Windshield & Air Vent & Desk, all places work perfectly. Perfectly suitable for sedan, pickup trucks, suv, taxis and more.
👍 MILITARY GRADE STURDINESS TEST – STRONG SUCTION CUP: The 2021 enhanced AINOPE dashboard cell phone holder car with 3 layers strong adhesive passed the military-grade sturdiness test, the maximum bearing up to weight of 55lb and withstand the temperature from -4°F to 194°F. ⭐⭐⭐NOTE: 1. Please clean dashboard first and wait 24 hours after installation and don’t touch the adhesive pad with fingers. 2. Please note extra dashboard pad only ONE-TIME USEING.
👍 THE EASIEST OPERATION & JUST SLIDE IN AND GO: Just slide in your phone, gravity phone car mount clamps the phone automatically by gravity and provide the easiest operation and a strong stable hold without close onto the side buttons. Easy to insert and remove your phone with one hand.
👍 UPGRADED AIR VENT CLAMP: This car cell phone holder mount is designed as “hook shape” and form “Three grasp points” which can vise the outlet blades tightly. This car phone holder has “Three Grasp Points” with shockproof rubber, which could hold the phone steadier than others, it solving the market’s common problem of being easy to fall off from the vent over time. NOTE: THE LENGTH OF CLAMP BETWEEN 0.41-0.98IN. THIS PHONE HOLDER ONLY COMPATIBLE WITH HORITABLE AIR VENT.
👍 UNIVERSAL COMPATIBILITY: This universal car mount for phone will firmly hold all the smart phones (4-7in) even with thicker case (≤14mm) compatible with All PHONE. NOTE:WE RECOMMEND USING THE SMALLER PHONE(<4.7inch) WITH PHONE CASE
👍 8.0 INCH LONGER ARM DESIGN, MULTIPLE VIEWING ANGLE: The car mobile phone holder equipped with firmest & most flexible telescopic arm that extends from 5.90″ – 8.00″ (153MM – 203MM ) and can pivot up or down 270° for optimal viewing height. You can have a wider sight and adjust this gravity cell phone automobile cradles up/down or left/right. NOTE: THE HORIZONTAL MODE IS NOT SUPPORTED. ❤️❤️Please 💌email the AINOPE-authorized store first for a solution, we will be sure to provide a satisfying
