AHD 1080P Backup Camera Monitor DVR System,4 x IR Night Vision Car Front Side Rear View Mirror Camera + 7″ IPS LCD 4-Split Screen for 12V/24V RV Bus Semi Truck Trailer 5th Camper
Price: $199.99
(as of Aug 10, 2024 20:15:13 UTC – Details)
Only need to connect the monitor power wire with car electronics system:
Red wire to car key on+,
Yellow wire to car battery+
Black wire to GND,
Green Blue Grey Brown wire to reversing or other Trigger+ (or No need to connect)
Insert the Memory to the card slot and press Mode button to record
Simple to installation,Easy to use Easy to mount
Best for All Heavy Vehicle such as semi Box Truck Trailer Bus RV 5th Wheel Camper Pickup Boat School Bus Tractor Motorhome
7″ Large DVR Recorder Monitor with 4-split
Display Size:7 Inch AHD DVR Screen
Power requirement:DC 12V-24V
Consumption:8W
Video:4 channels input ,Quad Split Screen Display
Our Split monitor can display 4 video at same time
Full images/3 images/4 images adjustable
Build in SD DVR Great Loop Recording functions
Each camera Record with a separate video
Record video Can be find out easily by video playback
Come with 32GB SD Memory Card, Max support 128GB
Reverse Grid Lines Can be turn on or off
Image Can be adjust for mirror or none Mirror
Image Support Flip with Upside Down
Suitable for Front view/ rear view/side view
360°clearly View to avoid blind spot
Net Weight: Approx. 1000g
Lauguage:English,Chinese
AHD 1080P IR Backup Camera
100% Not Wash Out AHD 1080P Sensor Mirror image
Lens:2.8mm(120 View angle )
Number of pixels:2.0 MP Camera(1920*1080)
Minimum illumination:0 LUX
Night vision:LED IR
Video Output:4Pin Aviation Connector
work Temperature:-20°C~+60°C
Power Requirement: DC 12V
Waterproof:IP 69
Wired 4 Backup reverse Camera System with DVR Monitor: 7 inch Large screen with 4 x IR Reverse Backup rear Camera Hard wired version Camera system, stable video No worry about lost signal during driving ,guarantees safe and 360°View clear image Avoid Blind spot
4 Pin 7 inch IPS rear view monitor build-in DVR ,4 channels video input ,4-split screen display,It can display Full images/3 images/4 images,Image can be adjust for mirror or none mirror or flip with Upside Down ,come with 32GB SD Memory for Video Record,video Can be find out easily by video playback
HD 1080P 2.0 Megapixel Rear Camera IP68 Waterproof with 4 Pin aviation Connector( Shockproof), 2x 18 LED IR Night Vison Car AHD Backup reversing Camera and 2x 12 LED IR Back up side view Camera , 100% Not Wash Out AHD 1080P Sensor HD Rear View Camera, wide view angle
The Back up Camera System come with 4 reverse cameras,and 5m 10m 20m 4-Pin Extension cable Best for Long Truck Trailer RV Bus Motorhome Schoolbus Camper Lorry 5th wheel Camper Semi Box and All other heavy Vehicle
3x trigger wire can be connect for reversing light,turn left light ,turn right light ,car rear view camera can be viewed simultaneously from the Reverse Rear Side views in one Large display, Protect your driving safety far away with Danger
