Price: $16.99
(as of Aug 12, 2024 09:45:31 UTC – Details)
Colder, Faster, Longer.Multi-function,Multi-purpose
An ice alternative that far outperforms ice, AGECASH reusable ice packs are designed to provide extended cooling at 18 degrees F that can last up to 10 hours. Great for camping, picnics, boating, fishing, tailgating, and any perishable transport (both personal and commercial)
A Free Gift
We give away a silicone funnel for every ice pack.For every ice pack, we give away a free silicone plug
Instructions for Use
The inside of the ice pack is filled with a proprietary cooling gel mixture, just add water at home, shake and seal, and then turn it into a solid block after freezing, which creates a reusable ice pack. Add14OZ of water to each ice pack
Superior Cooling Performance
AGECASH ice pack started from the freezer at 4°F, reached 32°F at 20.0 hours, and reached 40°F (the maximum recommended temperature for keeping food refrigerated) after 24.4 hours
AGECASH ice pack has a fresh-keeping effect after being tested in a room at 70°F for 24 hours.
Add Water Once & Reusable
Just add water once and return the ice packs to the freezer after using and they’ll be ready for your next outing. Save your money spending on ice cubes.
Lasts longer than regular ice packs
When paired with a high quality cooler, ice packs will keep your food and drink chilled longer Let you eat fresher food
4 layers of molecular material
4 layers of molecular materials to provide more excellent quality and preservation function, durable products
More economic and affordable
AGECASH ice packs will pay for themselves in just a couple outings — and no extra trip to the store.
FAQ
Are these reusable or one time use only? They are reusable. Whether you’re camping, fishing, or Put it in your lunch bag, you can use this ice pack to keep your food fresh
Do I need to refill the packs? No, you do not need to refill your ice packs. Once they are sealed, they should not be opened or emptied
Are these safe to put in a zero degree freezer? Most freezers are 0 degrees and our packs were designed just for that, so it will be just fine.
Would these work for shipping frozen fish? Yes! Please check our chart about the number of packs to use based on your cooler size.
Package Dimensions : 7.8 x 7.17 x 1.69 inches; 5.61 ounces
Item model number : 1140
Date First Available : July 19, 2021
Manufacturer : AGECASH A
ASIN : B09GJL43HC
【5 Pack of Ice Packs】: AGECASH A ice pack for coolers is more durable than lunch box ice cubes. Each freezer pack measures 7.5 x 6.5 inches and is colder than 18°F (-8°C) ice. Meets your food and beverages keep cooling for 8-10 hours.
【Safe and Reusable】: Reusable portable ice packs are made of sturdy 100% safe material, easy to clean, and can be used repeatedly. Cold packs for cooler are more practical than ordinary ice cubes.
【Strong Cooling Durability】: Cooler ice packs filled with gel can maintain cooling for longer than ordinary ice packs that only add water. Gel ice packs are a great choice for outdoor travel activities without a refrigerator.
【Easy to Use】: Use our collapsible funnel to add the appropriate amount of water (Please add 14OZ water), shake, screw cap, freeze until use, in order to obtain better freezing power, please freeze the night before use.
【Wide Application】: Whether placed in a lunch bag or lunch box, cooler bag, lunch cooler, to keep your food and drinks cool, you can also use these ice packs to relieve injuries, but the packaging needs to avoid direct contact with the skin.
