Price: $79.99
(as of Sep 15, 2024 06:30:16 UTC – Details)
GOCOM G600 Walkie Talkies For Adults Professional Long Range Two-Way radios
If you are hiking in the mountains where there is no cellular signal, you can easily and reliably maintain one-to-one & one-to-many communication.
Safety comes first for all outdoor group activities, and keeping in touch must be the first priority.
Real time communication ensures everyone’s safety in the wild and enables you to share feelings along the journey.
Frequency Range:462.55-462.725MHz,467.5625-467.7125MHz UHF,
This frequency band belongs to the free frequency band of American radio and does not need to spend money to purchase or license to use.
Helps You Understand the True Ranges to Expect While Out on Your Adventures.
FRS radios use a standard set of 22 frequencies granted by the FCC.They all have fixed antennas and use a maximum of 2 Watts of power.
Obstacles:
UHF radio waves are weakened and can be blocked by obstacles. Obstacles such as trees will lower radio range while obstacles such as mountains can be expected to completely block transmission. So even though forested areas do attenuate the signal, in these regions you should expect your range to be limited far more by the hills blocking your signal than the trees absorbing it. In more urban areas, buildings will significantly block your signal. Most concrete, brick or metal structures reflect all radio waves. In cities, with a 2 Watt radio, you usage range is about 1 mile.
Despite range limitations, walkie talkies can still be very useful for making outdoor sports safer and more fun. There are many sports where range will rarely be a cause for concern due to the nature of the sport – for example, rock climbing where partners are usually on a shared rope or paragliding where terrain is often not a factor. This same rule applies to sports such as mountain biking, hiking, trail running, etc.
NOAA Weather Alert
Keep updated with real-time weather conditions by turning on the weather channel or initiating weather alerts when talks, NOAA radio service may not be available in all areas.
IPX4 Waterproof
No worries about using it in the wildest area and outdoor games. With the IPX4 waterproof design, G600 walkie talkies withstands the effects of rain or other water splash conditions.
Do not soak
LED Flashlights
Keep your safe in outdoor. LCD Blacklights screen provide clear vision on walkie talkies screen wheather in day or night and built-in flashlights provide a vision on road.
Adjustable Volume
The sound is loud and clear with adjustable volume level,you can change the tone according to your mood.
Where else is GOCOM G600 walkie-talkie applicable?
It is great for outdoor exploration, camping, hiking, fishing, biking, hunting, etc…
It can also be widely used in work to improve work efficiency.
For example, restaurants, construction sites, farms, clinics, etc. can all communicate effectively to solve problems in a timely manner.
Sometimes what should I do when I am afraid of noisy others or do not want to share our conversation?
It doesn’t matter, we have earphones for you! ! Each walkie-talkie is equipped with a single-ear G-type headset, appearance is close to the ears and multi-shaped, The earplugs can be adjusted 360°, so that the easily fit in the left or right ears to maintain the privacy of the call. with clear sound performance and noise reduction, easy to use and concealed for calls.
AA-1200 mAh Ni-MH rechargeable battery
There are three ways to power your radio for up to about 15 hours continuous using time and it can standby for about 20 days. 1.Use the included USB quick charger; 2.Use seat charger can charge two at the same time; 3.Get more spare rechargable AA battery.
Danger Quick Alarm
Roger Tone: Confirmation tone indicates the completion of the user’s transmission, and signals others it is clear to talk.
Key Lock: When activated, provides key pad security eliminating accidental channel changes.
Power Save: If there are no transmissions within 5 seconds, the unit will automatically switch to battery save mode.
Auto Squelch: Automatically shuts off weak transmissions or unwanted noise even in nosie place.
Microphone Headset: Allows use Headset with mic in public place.
4.0 out of 5 stars
1
4.0 out of 5 stars
59
4.2 out of 5 stars
59
4.3 out of 5 stars
154
— $159.99$159.99
Charging
Single base charging / UBS socket charging Single base charging / UBS socket charging Dual base charging / UBS socket charging / AA battery Dual base charging / UBS socket charging / AA battery AA battery
Battery Type
lithium battery lithium battery AA Ni-MH rechargeable battery / Ordinary alkaline battery AA Ni-MH rechargeable battery / Ordinary alkaline battery Ordinary alkaline battery
Whether it Comes With Batteries
NO
Whether it Comes With Earphone
no
Waterproof Level
IP5X IP5X IPX4 IP67 IPX4
Waterproof Level Explanation
5 means that the inside of the shell is completely prevented from entering dust, and X means that there is no waterproof test requirement(not waterproof). 5 means that the inside of the shell is completely prevented from entering dust, and X means that there is no waterproof test requirement(not waterproof). Not dust-proof and has no harmful effects from splashing water in any direction. It can be used on rainy days but not soaked in water. Completely prevent dust from entering; completely waterproof, protection against short-term soaking, can be soaked (in the depth of 1 meter of water to prevent the impact of 30 minutes of soaking) Not dust-proof and has no harmful effects from splashing water in any direction. It can be used on rainy days but not soaked in water.
Distance
1-32miles Indoor coverage up to 900,000 square feet. 1-32miles 1-35miles 1-16miles
Product Dimensions : 2.17 x 1.57 x 7.09 inches; 2.94 Pounds
Item model number : G600
Batteries : 12 AA batteries required. (included)
Date First Available : October 13, 2020
Manufacturer : GOCOM
ASIN : B08L5JDF12
Country of Origin : China
IPX4 Waterproo-With the IPX4 waterproof design can prevent splashing water from having any harmful effect on it. Ideal for adults in outdoor activities hiking camping road trip as well as for kids to keep in contact with parents.
NOAA Weather Alert – 11 NOAA alert channel can help you get the latest weather and a alarm of severe weather, US only. And locks onto the strongest weather channel to alert you of severe weather updates. NOAA Weather Alert will sound an alarm indicating that there is a risk of severe weather in your area, and you will always be prepared for the unexpected.NOAA radio service may not be available in all areas.
VOX Function & Auto Squelch – VOX function offers voice-activated hands free operation, it can be a good tool for you when you are snowshoeing. Automatically shuts off weak transmissions or unwanted noise even in noise place.
GOCOM Walkie talkies with decent range and crystal sound for smooth communication;20 different call tones allow you to transmit a tone to other radios in your group to alert them that you want to talk;keypad lock can lock your personalized settings
