ACOPOWER 400 Watt Solar Panel Kit, 4 Pcs 100W Polycrystalline Off-Grid System for RV Home Marine with 40A MPPT Charger Controller/Z-Brackets/Y Connectors/Solar Cables/Cable Entry Housing
Price: $388.65
(as of Aug 26, 2024 06:45:30 UTC – Details)
3333
2222
11 12V Solar System Designed for off-grid use with the ability to easily charge most 12V batteries:
GelSealedFlooded (Wet Cell)Lithium Ion
ACOPOWER 400W Solar Panel Kit | 40A MPPT Charge Controller
This 400W Solar Kit is designed with off-grid in mind. Suitable to mount on RVs, green homes, cars, and boats.
Solar Module: 4PCS 100W PolycrystallineMPPT Charge Controller: 40A MPPT Cables: 1 pair 30ft 12AWG cable with female/male connector to connect to the charge controller, 1pair 8FT 8AWG Tray Cable to connect the charge controller to your battery;Mounts and cable Entry housing: Four sets of z-brackets and a waterproof cable Entry housing1 Pair 1Y4 Branch Connector:1 male to 4 female(M/FFFF) and 1 female to 4 male(F/MMMM).
100w Poly Solar Panel100w Poly Solar Panel
40A MPPT40A MPPT
2222
400W KIT400W KIT
100W Poly Solar Panel
Specification
Peak Power (Pmax):100W Peak Circuit Voltage(Voc):22VMax Power Voltage(Vmp):17.48VShort Circuit Current(Isc): 6.21AMax Power Current(Imp):5.72AWind resistance: 2400paWeight:17.6 lbDimension:40.2*26.4*1.4 InchApplication Class:Class A
System nominal voltage: 12/24VDC automatically identifying system voltage except the lithium-ion battery. Battery voltage range: 8~32VRated charge current: 40AMax. PV open circuit voltage: 100V at At minimum operating environment temperature /92V at 25℃ environment temperatureMax Input Power: 520W/12V,1040W/24VBattery type selection: lead-acid (Gel, Sealed, Flooded) and LithiumNegative Grounding DesignMPP voltage range: (Battery voltage +2V)~72VInstallion Notes: First connect the battery;Then connect the load; Finally connect the solar panel.
Z Brackets
4 Sets Mounting Z Brackets
Cables and Housing
30ft 12AWG PV Cable with female/male connector
8FT 8AWG Tray Cable
1pc waterproof cable Entry housing
1 Pair 1Y4 Branch connector:1 male to 4 female(M/FFFF) and 1 female to 4 male(F/MMMM).
400w40a poly400w40a poly
How to properly set up a basic system
First, the battery should be hooked up to the charge controller. You could use our tray cable or any general stranded copper core wire to connect the two. Make sure that you lead the wire into the battery terminal of the charge controller and match the + and – to the battery + and -. Make sure to screw in the exposed wire tightly inside the controller terminal. Then screw on the battery rings to the battery.
Second, then connect your solar panel to your charge controller. We recommend that you connect the adapter kit to your panel first, then follow the + or – sign coming off of the leads of the panels and match it with the + and – sign on the charge controller. Be careful at this step, because if the panel is inserted incorrectly, you can have reverse polarity and short the system causing damage to the panels or controllers.
Lastly, you can hook up your inverter to your battery by using battery ring cables and by matching the + to + and – to -.
4.5 out of 5 stars
293
4.5 out of 5 stars
293
4.5 out of 5 stars
293
4.5 out of 5 stars
293
$169.90$169.90
— $388.65$388.65
100W Solar Panel
1PC 2PCS 2PCS 3PCS
Charge Controller
20A PWM 20A PWM 30A MPPT 30A MPPT
30FT PV Cable
8FT 8AWG Tray Cable
Cable Entry housing
Mounting Z Brackets
1 Set 2 Sets 2 Sets 3 Sets
4.5 out of 5 stars
293
4.5 out of 5 stars
293
4.5 out of 5 stars
293
4.5 out of 5 stars
293
— $648.00$648.00 $909.83$909.83 $1,198.00$1,198.00
100W Solar Panel
4 Pack 5 Pack 6 Pack 8 Pack
Charge Controller
40A MPPT 40A MPPT 50A MPPT 60A MPPT
30FT PV Cable
8FT 8AWG Tray Cable
Cable Entry housing
Mounting Z Brackets
4 Sets 5 Sets 6 Sets 8 Sets
[Solar Starter Kit] 400W solar panel kit is fully equipped, and the necessary accessories from input to output are covered in it, which is ideal for novice and customers who are looking for convenience. This solar kit includes 4pcs 100W poly solar panel, 40A charge controller, 4 sets mounting z bracket, 30ft 12AWG PV cable, 8ft 8AWG tray cable, cable entry housing, 1Y4 branch connector.
[Ideal Choice for Permanent Installation] Advanced laminated technology and long-lasting ETFE material of 100W polycrystalline solar panel supports high light transmittance, scratch-resistant and easy to clean. And anti-reflection tempered glass and corrosion-resistant aluminum frame reinforces safety and impact resistance, which allows each panel to withstand high wind (2400Pa) and snow loads (5400Pa). Solar panel for rooftop is perfect for permanent or semi permanent installation.
[Monitor & Protect Devices] 40A MPPT uses maximum power point tracking technology and automatically regulates charging profiles relative to ambient temperatures, providing the best level of charge in any condition and protecting against over-charge, over-discharge, overload, and short circuit. User programmable for battery types, load control etc, via PC software or remote meter MT-50.
[Wide Application & Compatible] Solar panel kit is designed for RV, cabin, rooftop, caravan, shed, greenhouse, boat, back-up and remote power use, which can be connected in parallel for 12V battery charging or in series for 24V battery charging. And compatible with lead acid, AGM, gel, and lithium batteries. 40A MPPT of 400 Watts RV kit allows expansion to 1040W in series and 520W in parallel.
[25-year Power Output Warranty] We offer a 25-year transferable power output warranty on solar panels and 1-year warranty on rest of the kit components. ACOPOWER solar panels are factory-automated production without manual participation, so the probability of damage is low. If the panel you received is damaged due to transportation, please contact us as soon as possible.
