Price: $127.23 - $105.47
(as of Aug 20, 2024 12:45:30 UTC – Details)
Please note that this is NOT a smart TV, the resolution is 1024x600P, 70 minutes of playback time when fully charged.
Portable TV, ATSC-compliant for digital TV (analog TV not supported)
With 12V car charger (24V big cars is not applicable), convenient to use.
Question: How long does it take to charge a battery? How can I tell how much power is left in the battery?
Answer: Charge for 3 hours, the red light goes out when it is full; when the product is almost dead, there is a battery symbol flashing on the screen.
Digital Television 10 inch
Siginal: ATSC
Supported format: MKV, MOV, AVI, WMV, MP4, FLV, MPEG1-4, RMVB
Multiple external sources: AV input/output, HDMI, VGA, SD and MMC card and USB devices
Resolution: 1024×600
Loudspeaker: 2 x 32 mm round loudspeakers
Battery for remote control: 2 AAA batteries (not included)
TV size: approx. 26×16.5×2.7CM
Screen size: 12.7×22.3CM
Playback time on full charge: 70 minutes
Package list 1 x Digital TV 1 x Base 1 x Car charger 1 x Power Adapte 1 x Foam pad 1 x Antenna 1 x AV Cable 1 x Remote Control
DIGITAL CAR TV: This car digital TV allows you to watch HD TV programs and listen to clear FM radio stations and music in the car. Portable TV, which complies with ATSC, can watch digital TV (analog TV is not supported). A digital TV tuner with ATSC can produce true colors to achieve a more realistic visual effect.
10INCH TV: The 10 inch LCD portable TV, 26X16.5X 2.7cm, 12.7X22.3cm screen size. 1080P HD ensures ultra-clear pictures and videos. In addition, it also supports external sources, including AV input/output, memory and MMC cards, USB devices, etc.
MULTIPLE INPUTS: It also supports car digital TV, AV input/output, FM radio, SD and MMC card and USB device, VGA, HDMI. Remote control makes more convenient and easier.
RECHARGEABLE BATTERY: Equipped with 1500mah rechargeable lithium battery, and 12V car charger, Full can be used for 70 minutes, suitable for the car and long road trips.
APPLICABLE COUNTRIES: Canada, the United States, Mexico, El Salvador, Dominican Republic, Puerto Rico (U.S.), U.S. Virgin Islands. If there any issue about this product, please us, we will give the best solution in the first time. we guarantee replacement or refund.
