A-iPower Portable Inverter Generator, 1500W Super Quiet, EPA & CARB Compliant CO Sensor, Portable Ultra-Light Weight For Backup Home Use, Tailgating & Camping (SUA1500i)
Price: $429.00
(as of Aug 08, 2024 06:30:25 UTC – Details)
Do more with the A-iPower SUA1500i gasoline powered Inverter Generator. Providing an impressive 1,500 starting watts and 1,200 running watts it is perfect for tailgating and camping. 2 units can parallel together with the included parallel kit to power essential household items or for power on the jobsite. Advanced inverter technology makes this unit safe for sensitive electronics. Ultra-lightweight design is only 28.5 lbs. for easy carry and transport, the 60cc overhead valve engine combined with idle down technology provides up to 8-hours of run time at 25% load and 6-hours of run time at 50% load with it’s 0.7 Gal. fuel tank. Comes with a fully loaded control panel consists of CO sensor indicator light, data indicator lights, 1x Duplex 5-20R 20A 120VAC, 1x 3.6A USB-A, 1x 3.0A USB-C, parallel capable. Our portable inverter generator is PGMA compliant, EPA CARB certified & is equipped with a CO sensor with auto shutdown technology. Our portable inverter is parallel equipped & comes with a parallel cable. A-iPower stands behind its products.
Powerful Engine: 60cc OHV high performance 4 cycle engine. Fuel-efficient, reliable, powerful providing long life and excellent heat dissipation.
High Output + Quiet: 1,500 starting watts 1,200 running watts. At only 52dB this powerful portable inverter generator is the ideal product for your tailgating and camping needs.
Pure Power: 3% THD of clean power output. Inverter technology provides clean stable source of power for sensitive electronics such as, laptops, TV’s, phone chargers and sensitive power tools.
Fully Loaded Control Panel: The control panel consists of CO sensor indicator light, data indicator lights, 1x Duplex 5-20R 20A 120VAC, 1x 3.6A USB-A, 1x 3.0A USB-C, Parallel Capable.
Low Idle Technology + Compact Design: Lightweight for easy transport weighs only 28.5 lbs!. Extended run time of 8hrs at 25% load with 0.7 gallon fuel tank.
