9″ HD Backup Camera System Kit with Monitor, Loop Recording, Wired Rear View Camera, IR Night Vision Waterproof Camera with Safe Parking Lines for Bus, Semi-Truck, Trailer, RV, BY902A
Price: $238.99
(as of Aug 10, 2024 02:45:29 UTC – Details)
BY904ABY904A
ZEROXCLUB BY902A HD 1080P IPS Monitor Wired System with 2 Rear View Cameras
ZEROXCLUB is a brand focus on providing premium quality backup camera. After 12 years of growth and having 9 years of research, we provided unique products and service for thousands of customers. To bring you a safe and convenient journey, we committed to improve and upgrade our products continuously.
No matter you want to know us or want to use the camera better, ZEROXCLUB will be always at your service.
The BY902A wired backup camera is attached to the display screen via cables all the time, so that you’ll get a bright and clear picture. You don’t have to worry about signal interference or the frequency of your link and expect a clear and uninterrupted video.
Versatile — They can be mounted on RVs, trailers, 5th wheels, farm equipment, Campers, Bus, Vans, and construction, among many others.
More Trustworthy– 3 YEAR Advanced Exchange Service. ZEROXCLUB provides you a free replacement during the limited hardware period. If you have any quetsions about the products, please feel free to let us know.
BY904ABY904A
Key Features of Cameras
Night Vision — 18 bright IR LED lights on camera to provide clear image during night time driving.
IP69k Waterproof — With IP69k waterproof performance, ZEROXCLUB backup camera can prevent water from seeping into the camera and withstand the temperature range from -4℉ to 140℉, which is able to withstand extreme weather like wind, rain and snow.
Parking Guide Lines — It can help you to judge the distance between your car and the object around it, which can make your parking safer and easier. (You need to connect the Green wire to get the parking guidelines)
Wide Viewing Angle — The BY904A provide a healthy horizontal viewing angle, you can see things behind you at a glance.
BY904ABY904A
Key Features of Monitor
Loop Recording — It will record what is displayed on the monitor and overwrites the oldest footage with the newest upon filling a memory card to capacity. (a 32GB memory card is included)
Support Split Screen View — Monitor can display 1 full camera view, or dual split screen view. Just press V₁/V₂ button on the monitor to switch views.
Mirror Image — The view in your monitor can be reversed to front view/rear-view. It’s handy if you would like to use the camera as a front-view camera.
Vivid Imagery — IPS panel for wide viewing angles and vivid colors, with reasonable color accuracy and resolution to let you recognize any objects in view. The BY902A wired reversing camera kit always managed to give us a clear, useful image that we were confident in using to back up a car.
BY902ABY902A
Easy to install
Peace of Mind — The cabling can get sharp, focused images faster. For maximum security, you will see exactly what is happening behind you REAL-TIME. And this is more than capable of delivering an uninterrupted and high-resolution picture.
Red wire: Connect the Red wire to Vehicle ignition (ACC 12V+), connecting the Red wire to Vehicle ignition will power up the system while ignition is turned ON.Yellow wire: Connect the Yellow wire to Vehicle battery 12V+.Black wire: Connect the Black wire to Vehicle ground.Green Wire: Connect the Green wire to the vehicle reversing lights 12V+ as a trigger wire.4-Pin cable: The 4-pin connector to the cameras as wiring diagram showed.
Two Ways to Mount Monitor — The BY902A wired backup camera system comes with a U-shaped Bracket and a Fan-shaped Bracket. You can choose to install the monitor on the dash board or windshield according to your needs.
BY902ABY902A
Appearance Dimension of monitor (without bracket): 8.9 inch(L) * 6.02 inch(H) * 1.03 inch(W)
Appearance Dimension of rear view camera: 3.11 inch(L) * 2.56 inch(H) * 2 inch(W)
What is in the BOX?
9-inch Monitor x1Rear View Camera x2Extension 4-pin Cable x2U-shaped Monitor Bracket x1Fan-shaped Bracket x1Screw & Bolt Set x1 Remote Controller x132 GB Memory card x1
If you found an accessory is missing or damaged, please see us for a replacement.
297
297
4.2 out of 5 stars
181
4.2 out of 5 stars
181
4.3 out of 5 stars
264
4.3 out of 5 stars
264
$379.99$379.99 $238.99$238.99 $429.99$429.99 $239.99$239.99 $259.99$259.99 $189.99$189.99
Monitor
9‘’ 9‘’ 10‘’ 10‘’ 7‘’ 7‘’
Number of cameras
4 2 4 2 4 2
Waterproof
IP69k IP69k IP69k IP69k IP69k IP16k
Resolution
1280*1080 1280*1080 1280*1080 1280*1080 1280*1080 1280*1080
Night Vision
Mirror image
Split Screen
Single/Dual/Quad Single/Dual Single/Dual/Quad Single/Dual Single/Dual/Quad Single/Dual
Compatible Vehicles
RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach/So on RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach/So on Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach/So on Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach/So on RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach/So on RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach/So on
🍀Upgrade Wired Backup Camera System: This model BY902A is a wired 9 inch monitor system, which was designed for the bus, semi-truck, trailer, RV, camper specially. It comes with all the accessaries for easy installation. With the metel “U” shaped bracket, you could mount the monitor on the dashboard, or mount it to windshield with the suction cup. The Camera comes with a low-profile bracket and a set of larger brackets for more flexible mounting. Voltage ranging: 12 to 24V DC power
🍀Loop Recording & Safe Driving: ZEROXCLUB wired backup camera is a good safety option for reversing, because the wide view — 120°angle can help to see the area behind your car easily. If there have children / obstacles / others behind your car, you can see them with the help of the backing camera. Loop video recording function allows it to record what is displayed on the monitor and overwrites the oldest footage with the newest automatically. (a 32GB SD card comes with the package)
🍀Split Screen and Parking Guidelines: The monitor can show the full view for a camera, or dual split screen view, just press CH- button on the monitor to switch views. With the parking guidelines, it can help you to judge the distance between your car and the object around it, which can make your parking safer and easier. What’s more, you can change the image to front view or rear view, so you can use one of the camera as the front view camera. Monitor dimension: 8.9 inch(L)*6.02 inch(H)
