Price: $89.99
(as of Sep 06, 2024 17:45:11 UTC – Details)
Product Name: 9″” AHD Car Backup System, 9 inch IPS DVR Monitor + 4 AHD Cameras(3 Mirror image and 1 Non-Mirror image) with 4-PIN Aviation Plug 4 CH Simultaneous Recording for Truck Bus Trailer Motorhome Caravan Camper Surveillance 12V-24V Night Vision
【AHD IPS Montior】
Display Size: 9 inch IPS AHD Screen
Resolution: 1024(W)xRGBx600(H) max support 1080p
Brightness: 500 cd/m2
Wide Power input Range: DC 9V-36V
Preview: Support single and multiple images
Video: 4 channels video input and simultaneous 720P recording
SD Card Slot: Support Upto 256GB
【4 AHD Cameras】
Lens: 3.0mm
Pixels: 1.3 million pixels
Grid Lines: No
Viewing Angle: 120°View angle
Work Temperature: -20~70 Celsius Degree
Backlight Compensation:Auto
White Balance:Full Auto
Night Vision:Yes, Complete No-light Night Vision
Video Output:4-PIN Connector
Waterproof:IP 68
Easy to install:
Connect the monitor power cable with car electronics sytem:
·Red wire to ACC
·Black wire to GND
·Yellow wire to Car 12V-24V
·Blue Brown Gray and Green wire to Reversing Trigger+ (or No need to connect)
Package includes:
AHD 9″” IPS monitor x 1
AHD Front Camera x 1
AHD Mirror Image Camera x 3
Monitor Power Video Cable x 1
16FT/5m 4-PIN Video Cable x 3
65FT/20m 4-PIN Video Cable x 1
Remote Control x 1
Dashboard Bracket x 1
Bracket Screws x 4
Screws x 18
User Manual x 1
[9 inch 12-24V Monitor] 9″ IPS truck parking backup system with 4 channels recording. High resolution with AHD signal. Monitor automatically switch to rear view picture when reversing. Backup camera monitor support switching to 2 or 4-split display. Clear see what’s in front, sides and behind of the car to avoid any risks or accidents. With dashboard stand. Operate by remote control or buttons.
[4-Channels DVR Recording System] Max Card Memory Support Upto: 256GB (NOTE: Memory card is NOT included in the package) The parking system comes with front, rear & 2 side view cameras and 4-channel simultaneous 720P HD video recording. Car backup camera will generate separate video files from each camera.Vehicle backup camera Loop recording: automatic deleting previous files when the card is full.
[4 AHD Night Vision Cameras] 4 Analog HD signal cameras with high sensitivity sensor, made of durable metal shell, IP68 Waterproof. Trailer backup camera can perfectly work even if under complete no light environment, and make sure you can still see a clear picture at night time. All cameras are Full color picture, no color difference in dark or bright place.
[Waterproof & Universal Intallation] Backup camera for truck with IP68 waterproof metal shell, the backup camera for car can work very well under any weather conditions and good for long time using. Compatiable with any 12V and 24V vehicles like truck trailer bus vans camper motorhome caravan etc. 4-PIN aviation plugs(shockproof, waterproof) to keep the system more stable.
[RELIABLE CUSTOMER SERVICE] Ready to respond within a 24 hour time frame. 30-Day Money Back, 12 Month Replacement Warranty and Lifetime Support. (Package includes: AHD 9″ IPS monitor x 1, AHD Front View Camera x 1, AHD Mirror image Camera x 3, Monitor Power Video Cable x 1, 16FT/5m 4-PIN Video Cable x 3, 65FT/20m 4-PIN Video Cable x 1, Remote Control x 1, Dashboard Bracket x 1, Bracket Screws x 4, Screws x 18, User Manual x 1.)
