Price: $34.99 - $24.99
(as of Sep 06, 2024 21:00:19 UTC – Details)
Emergency Radio
Product Dimensions : 6.8 x 3.1 x 3.8 inches; 1.16 Pounds
Item model number : ANHN008
Date First Available : October 5, 2022
Manufacturer : FVTLED
ASIN : B0BHC5CFDH
【Emergency Supplies】The US suffered 28 major weather disasters in 2023, including Tornadoes, Extreme-heat and Cold, Floods and Hurricanes. The FVTLED survival gear NOAA emergency radio will provide the necessary resources to keep you safe, get power, lighting, news and call for help in an emergency,noaa emergency weather radio is an excellent hurricane supplies. and every family should order an NOAA alert weather radio to anticipate danger and be prepared!
【8000mAh Rechargeable Battery & Multiple Charging Options|】 Built-in 8000mAh large battery hand crank radio is a portable power bank, dual USB output can charge two Android/ iPhone/ iPad small devices at the same time, Keeps radio running for up to 72 hours in the event of an extended AC power outage. Solar panel and handle can be used in emergency situations, the outdoor survival radio charges via a Type-c /Hand Crank/Solar or replace the radio battery to get power quickly, Suitable for Outdoor Camping/ Exploration/Hiking/Hurricane/Tornado/Earthquake emergency kit.
【AM/FM/NOAA Alert Weather Radio】 Designed for emergencies, the Emergency Radio will automatically scan for weather channels and will automatically sound an SOS alarm in critical moments, allowing you to be fully prepared for dangerous weather such as hurricanes, tornadoes, and severe storms, keeping you and your family and friends safe. Upgraded 12.6-inch antenna for enhanced signal. Ensures functionality even in extreme environments.
【Essential Camping Hiking Supplies】Powerful Outdoor Survival Gear Hand Crank Radio with Bright Flashlight and COB Reading Light, Far Beam and Near Beam (300 Lumens) for Different Lighting Needs to effectively illuminate your surroundings and keep it bright in case of a power outage. You can also use the 3.5mm headset radio to enjoy your afternoon without disturbing your family and neighbors.
【SOS Alarm & Compact Compass】When you’re stuck in a house by floodwaters or lost in the woods, you need to use special features to help people find you, this Emergency Radio with SOS Alarm feature has a loud SOS alarm that will help search teams quickly determine your location. Also, a mini compass is mounted on the radio to orient yourself if you get lost. Reduce your risk when exploring the outdoors. OUTDOOR SURVIVAL GEAR – Emergency radio for added safety for you and your family.
