7-inch Magnetic Solar Wireless Backup Camera System, Rechargeable Battery Reverse Camera with Loop Recording Monitor for RVs, Trucks, Trailers
Price: $219.99 - $159.99
(as of Aug 13, 2024 00:15:18 UTC – Details)
Camera SystemCamera System
Start your safe and ease journey with Nuoenx 7 Inch Magnetic Solar Wireless Backup Camera System!
Newly Magnetic Solar Wireless Backup Camera with Monitor – This system includes a 7 inch monitor and two magnetic wireless backup camera with 9600mAh rechargeable battery. Special Design for Car/SUV/Pickup/RV/Trailer/Truck/Camper.
CameraCamera
CameraCamera
CameraCamera
CameraCamera
CameraCamera
7″ Monitor with Loop Recording
The monitor has built-in video recording function to record the driving video, making your driving more convenient and safe.
4 Camera Channels
This system supports up to 4 magnetic wireless backup cameras, you can choose to display CAM1 to CAM4 in single view / dual view / quad view.
Waterproof IR Solar Backup Camera
With IP69K waterproof standard, the solar wireless backup camera can work in extreme weather from -4℉~176℉.
80° Adjustable Angle
The portable magnetic wireless backup camera can be angled up and down as needed.
CameraCamera
Zero Wiring, Zero Drilling
Plug in the included cigarette lighter to power the monitor.
With strong magnets at the bottom, the camera can be mounted on any METAL surface of the vehicle.
Everyone can install this magnetic wireless backup camera in minutes!
CameraCamera
🚚🚚 Magnetic Solar Wireless Backup Camera Kit – This wireless backup camera system includes a 7 inch loop recording monitor and 2 magnetic rear/front view backup camera. Adopts digital wireless transmission technology, presents stable and high-definition images for reversing or monitoring. It could delivers a stable image without any interference from other wireless signals.
🚚🚚 Solar Backup Camera with Strong Magnetic Base – Magnetic solar wireless backup camera base is equipped with a strong magnet, it can be firmly attached to any metal surface of the vehicle, no need to worry about the camera falling off while driving. No hard wiring, easy to attach and remove.
🚚🚚 9600 mAh Solar Powered Battery – The solar magnetic wireless backup camera supports both Type-C charging & solar charging. The solar backup camera has built-in 9600 mAh rechargeable battery. Solar panel charging is affected by factors such as sunlight intensity, panel size and battery capacity. Therefore, we recommend regular charging with a USB cable and solar charging as an aid to extending the camera’s operating time.
🚚🚚 HD1080P DVR Monitor – The monitor has a built-in 32GB SD card to record driving videos. With 1080 screen resolution, supports up to 4 cameras in single view / dual view / quad view, make your driving safer! Warmly tips: This system contains two magnetic backup camera wireless, if you want to add additional cameras, please contact Nuoenx customer service to purchase separately. Monitor size: 7(W)*6(H) inch. Magnetic Camera size: 4.25(W)*3.25(H) inch.
🚚🚚 Stable Signal Transmission Distance – The max wireless working range is over 328ft in open area ,and 50ft on vehicle for reversing or 36ft on vehicle for continuously use, which is long enough for most vehicles, like Cars, Trucks, RVs, Pickups, Camper, SUVs, Trailers, and Minivans.
