Price: $189.99
(as of Aug 31, 2024 00:30:18 UTC – Details)
ATPTK, THE EXPERT OF VEHCLE CAMERAS.
We are professional, in the field of vehicle camera for more than 14 years.
This is a two-camera kit. It can be used for any kinds of large vehicles, such as buses, box trucks, pickup trucks, garbage trucks, flatbed trucks, dump trucks, street sweeper trucks, refrigerator trucks, motor homes, vans, skid steers, farm tractors, combines, cotton pickers, crop sprayers, bulldozers, snow plows, forklifts, excavators, heavy equipments,etc.Cameras can be mounted at the back/front/side of your vehicle.Monitor can be mounted on the roof of the cab, or on dashboard.7″ Single view(NO SPLIT FUNCTION) monitor with two way video inputsPowered by vehicle power DC12-24V. Red wire to ACC 12-24V positive, and the black wire to negative(GND).Trigger wires are for turning signal power to make the monitor display when turing or reversing, or kept blank to display all the time.
High Resolution 1080P
High resolution 1080P monitor with digital LCD panel. It gives a super clear color image.
Normal/mirror image
Image can be set as normal, mirror or up-side-down by menu.This allows the camera to be mounted as rear view, font view or side view.
Adjustable Guide Line
When parking, with the guide line or rear distance scale on screen, there is no more guess for you when the bumper gets closer to the object behind.With the guide line, it helps you parking faster and safer.Guide line can be adjusted by menu. You can set your own distance value on the guid line.Connect the trigger wire to the power of rear lamp, then put your vehicle into reverse, the guide line will appear.
Take Up To 2 Cameras
7″ single view AHD 1080P (NO SPLIT FUNCTION)monitor can take up to 2 cameras, AV1/AV2.If the monitor takes two cameras, camera for AV1 will be on all the time to surveil, and when you back up, the monitor will be activated to display AV2 camera by the triger wire which is powered via the backup light, then you can see what is behind your vehicle.
AHD 1080P Waterproof Camera IP69K
These two cameras have the highest level of waterproof and dustproof rating IP69K. When raining, you also can drive safely.And they also has 10G vibration resistance rating.These are mini size cameras, especially for space-limit installation.
They are not only suibale for trucks, bues, caravans, etc., but also suitable for heavy equipments, farm tractors, skid steers, etc. in extreme condition.
Night Vision Cameras
Our cameras have 5pcs 850Nm IR lights. When driving at night, with our cameras, you are still able to see what is behind your vehicle.
Transient Voltage Suppressors (TVS) Built-in
The transient voltage often ocurs in the circuit of your vehicle when winding up/down the window, turning on/off the air-conditioner, etc. It may damage some devices in your vehicle, inluding backup cameras. No worry!Our monitor has been built-in with TVS to protect backup camera system from being damaged by the transient voltage.
What is in the package
7″ Single View (No Split Function)AHD 1080P LCD monitor X1AHD 1080P Waterproof camera X2Monitor U-type bracket, sunvisor and screw X1Monitor power cable X132ft extension cable X2
