500 Watt Inverter Power Inverter (Peak 1000W) DC 12V to 110V 120V AC Converter, car Adapter, 2AC Socket, 2USB car Charger, for Laptop, Smartphone
Price: $52.99
(as of Aug 17, 2024 01:45:13 UTC – Details)
vvvv
Continuous Output 500 Watts Input Voltage Rated 12Vdc (10-16V for lead acid battery,Please refer to the battery manual for other types of batteries) Output Voltage AC 120V 士10% 60Hz士1Hz Low Voltage Alarm 10vDC (Please refer to the battery manual for lithium battery ) Low Voltage Shut-off 9.5V土0.5V (Please refer to the battery manual for lithium battery High Voltage Shut-off 16V土0.5V (Please refer to the battery manual for lithium battery USB Output Current 5V 3.4A USB Ports Built-in smart cooling fan Automatically run when the temperature reaches 114°F or Output Wave Modified Sine Wave Overheat Shutdown 149℉±8℉ No load current 0.6A Built-in protections Overload protection,Over voltage protection,Low voltage protection,Over heat protection,Short circuit protection
FFFF
FFFFFFFF
BGBG
Multiple output methods are available
2*USB interface (5VDC, max. 2.4A)
2*AC 120v outlets
1 AC 120v hard terminal block for 500 power supply
This 500W power inverter is suitable for charging most electronic devices at the same time, with a maximum output power of 500W for all outlets.
Quiet and powerful cooling fan
For this 500W pure sine wave inverter, its smart cooling fan works automatically when the temperature reaches 45 soil 5°C to save battery power and extend the life of the cooling fan. In addition, we can enjoy a quiet environment, especially late at night.
Humanized hole design, can be hung on the wall, fixed without shaking, and a variety of environment placement.
DDDDDD
dddddddd
GGGGGG
24 months maintenance
7*24 hours caring service
remote control
Pure copper terminal
The connection of VOLTWORKS’s High-power inverter is with ringend which can enlarge the contact surface and reduce theresistance,not easy to get high temperature.
Please install the battery cables in the order shown in above figure.
Powerful enough for your household appliances like coffee maker, microwave, heater, washing machine… on your road trip, RVs, Cars, Vessels and emergency.
dddddd
dddddddd
■ [INPUT DC12V to OUTPUT AC 120V] 500W DC to AC Car Inverter: Provides 500W continuous DC to AC power and 1000W peak power with 2 AC outlets, 1 3.4A USB port, and battery clip and cigarette lighter adapter.
■ [Dual Connection Mode] In the car, you can use the cigarette lighter plug to connect to the car socket for appliances with less than 150W power, such as laptops, routers, cameras, drones, air pumps, etc. When the power of the appliance is between 150W and 500W, you need to connect the battery with alligator clips.
■ [Travel and emergency equipment] The converter is suitable for road trips, camping and outdoor work. It can also power lights, routers and fans in the event of a power outage by connecting deep cycle batteries.
■ [Advanced charging protection design] Built-in smart chip and fuse to prevent device overheating, overload, overvoltage, undervoltage, short circuit
■ [What do you get? ] 1 x 500W JARXIOKE power converter, 2 x battery clips, 1 x 12V car cigarette lighter, user manual. In addition, there is 24-hour professional customer service with 100% customer service satisfaction.
