4Patriots Liberty Band Emergency Solar Radio: NOAA Weather Warning Radio, Portable Power Bank, Charger & Flashlight – Solar Powered, Hand Cranked 3.7V/600 mAh Lithium Ion Rechargeable, AM/FM 7-channel
Price: $67.00
(as of Sep 11, 2024 10:15:19 UTC – Details)
Emergency Preparedness survival food Emergency Preparedness survival food
Shop 4Patriots
Shop Survival Food
Shop Solar / Emergency Power
Shop Emergency Hydration
Shop Camping Gear
Shop 4Patriots Best Sellers
Charitable Giving
Making a difference Making a difference
CHARGE FOR FREE USING THE SUN: You’ll have power as long as you have sun. Every radio has a 45 mAh solar panel built right in. It’ll charge your radio in a pinch. Perfect for power outages and emergencies.
3 MORE WAYS TO CHARGE: No sun? No problem. You can “fast charge” your emergency solar radios with the AC cord before the storm hits. Or use the hand-crank to get alerts in a storm. And of course, everyday batteries work great too.
NOAA WEATHER-ALERT PROTECTION: Listen to weather forecasts and news broadcasts24/7 from NOAA and AM/FM/SW stations. Plus, you can turn it to weather-band alert mode and your radio will stay quiet until you need extreme-weather alerts.
POWERS YOUR CRITICAL DEVICES: Use the power inside the Liberty Band Radio to give your phone or other critical devices a little extra “pinch” of power when you need it most. Simply use the cord that came with that device. Anything that charges via USB will work with your radio.
3-LED FLASHLIGHT: Built into your radio, you’ll get an ultra-bright flashlight. It provides lifesaving visibility for you and your family, even if the world goes dark.
