Price: $269.99
(as of Jul 29, 2024 00:15:13 UTC – Details)
VOONOA 4K RV Backup Camera System with 10.36 Inch Monitor for RV Truck Trailer Bus Semi Truck
Using the latest chip and advanced IPS 4K touch screen, you can operate easily and get a vivid view from the VOONOA RV camera system.Compared with a “wireless” backup camera system, VOONOA wired RV camera system can provide you with more stable signal transmission and real-time image without lag. With the built-in Bluetooth function, you can answer phone calls & play music on the 10.36-inch monitor via Bluetooth.Adopting the latest infrared LED lights, you can get a bright & clean view even in complete darkness.The 360-degree view from the front & rear & left side & right side view camera enables you to drive with more safety.Adjustable parking assisting line enables you to adjust the grid line according to different car models & different parking positions, making it easier to reverse.With the full glued tech and unique waterproof cover, the VOONOA backup camera with monitor system is capable of running well and long in all types of bad weather.Using a 12-36V power supply, the VOONOA vehicles camera system is VOONOA vehicle cameras system is compatible with any vehicle, such as an RV truck trailer camper boat travel trailer bus tractor, etc. The latest version of the VOONOA 4K RV camera system with10.36-inch full touch screen brings you the ultimate enjoyment & happiness, and is a must-have for travel and camping.
10.36 Inch Full Touch Screen RV Camera System
Backup Camera System with Bluetooth Function & MP5 Video Music Play Function
3 Ways to Install the 10.36 Inch Monitor
DVR & Loop Recording
Built-in DVR recording and loop recording functions enable you to record 4 channels continuously. You can check the recorded video locally on your monitor.
Wide Viewing Angle
Using the latest 165° wide viewing angle lens, the VOONOA rv camera system can provide you with wide view to avoid blind spots.
IP69 Waterproof
With the 4 layers of sealed glass lens, full gluing tech & unique waterproof cover, the VOONOA front view camera & side view cameras & rear view cameras can work great in all bad weather like heavy rain.
Infrared Night Vision
The latest large infrared LED lights can provide you with bright & clear vision at night. Night vision can reach 50ft.
Image Mirror Flip Function
The view of the 4 cameras can be flipped mirror image, up and down, left and right. Cameras can be used as front/left side/right side/rear view cameras.
Adjustable Parking Assisting Grid Line
You can adjust the parking assisting grid line on the full touch screen so that you can park/reverse easier and safer.
Specification of The VOONOA 4K RV Backup Camera System
Monitor Size 10.36 Inch Side Camera LED 16 PCS Front/Rear Camera LED 4 PCS Camera Real Angle of View 165 Degrees Waterproof Level IP69 Power Supply DC 12-36V Image Sensors 1080P HD Camera Operate Mode Touch Screen/Button Control
【4K Screen & 4 1080P Backup Camera】With the 10.36 inch 4K ultra HD 4-split touch screen & 4 pcs of 1080P Full HD camera, you can get sharper, cleaner and more vivid view on road to get the ultimate travel pleasure.
【Built-in Bluetooth】With Bluetooth function, the VOONOA RV camera system enables you to connect your cellphone iPhone to the monitor to play music and answer calls. Release your hands, focus on driving, and reduce driving risks.
【Great Night Vision View】Adopting the latest infrared LED lights & light sensor, the VOONOA backup cameras & side view cameras can provide you with at least 50 feet of night vision even in In complete darkness.
【IP69 waterproof 】 Using full-glue sealing technology for cameras & adding waterproof covers for all connections, the VOONOA truck system can work normally in various extreme bad weathers.
【Built-in DVR & Loop Recording】The DVR recording function enables you to record videos from 4 channels and can automatically save video in the event of an accident. Not support recording voice to protect privacy.
【Easy to Install & Wide Wide Adaptation】Compared with a “wireless” system, you do not need to provide power alone for all monitor & cameras, just connect the power wire once for the monitor and connect cameras with the monitor. Using 12-36 volt DC power, the VOONOA cameras system can be used for all vehicles like RV trucks trailers bus vans tractors the 5th wheel, etc.
【No Worry Service】VOONOA offers lifetime tech support, 3-year replacement service, and a 30-day money-back guarantee for the VOONOA 4K RV Backup Camera System. Check the manual book in the package to get more details.
